Kenmore Elite 45986 Front Load Washer Logo
C
Cathy Stewart Posted on Oct 12, 2015
How do I unlock the "control lock"
The "control lock" light is lit and I can't wash clothes. I am sure there is a code I need to put in to unlock but I can't find my manual
5 Related Answers
Anonymous
  • 750 Answers
  • Posted on Dec 24, 2008
SOURCE: Controls locked
Hello
Welcome to Fixya
My name is Huum,
To disable the control lock, hold the OPTIONS and SELECT buttons at the same time until the control lock light turns off.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Anonymous
  • Posted on Dec 30, 2008
SOURCE: Washing machine stops and door will not unlock
i had a problem similar to this but i was getting an error code on my display. it turned out the board was bad. you may want to try to do this yourself because it cost me almost double when the repair man came. i don't remember the part # but you could search it. i believe you just remove the front face of the washer also. to unlock the door there is a release switch in the bottom near the door handle. if you have a pedestal you have to remove the drawer or remove the bottom panel if you don't.
Anonymous
  • 91 Answers
  • Posted on Jan 02, 2009
SOURCE: Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Anonymous
  • 5 Answers
  • Posted on Mar 04, 2009
SOURCE: code "rL" means???
Code rL or F34 --> Load detected in machine at the beginning of the clean cycle. Push stop, remove clothes from washer & try again. Mine did this to me, even though there was nothing in the washer. I just tried it a second time & all is good again.
Anonymous
  • 5081 Answers
  • Posted on May 28, 2010
SOURCE: control lock light
Press and hold the DRAIN & SPIN button until the Control Locked light goes out. You will likely have to hold this button at least 3 deliberate seconds, maybe as long as 10 seconds to disable the control lock.
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
4helpful
On My Whirlpool Duet Model# GHW9150PW A setting kicked on that
3helpful
3answers
Control is locked
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
1helpful
"Controls Locked" light lit, unlock button has no effect
Have you tried unplugging the machine for awhile to let the board reset?
1helpful
2answers
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
3answers
Duet washer
PRESS AND HOLD CONTROLS LOCK/UNLOCK (END OF CYCLE SIGNAL)FOR 3 SECONDS.
Alexander
vince
