Question about Bosch PB10-CD Radio/CD Boombox
Have a PB10CD Radio and blue light comes on but nothing works.
Posted by Tim Brown on
My protection light was comeing on now nothing will come on ,& how can I get power to the remote wire from A factory Radio
If the factory radio has a power antenna output (typically blue or blue/white wire) you can use that to turn the amp on.
I have a blue pyle 12 inch 800 watt tube for my car. I've wired everything perfectly, yet when I go to turn on my radio, it doesn't work. The blue lights cut on, but the speaker itself puts out...
it could be few things one the light might come on but the preamp could be bad two could be a loose wire to sub three sub could be bad four make sure rca cables are good i hop this helps
When i plug the unit in the blue light comes on but the screen is blank and nothing works...?
there is most likely a hardware problem/ damage, it is likely the power regulator inside.
I have a 2008 jeep wrangler sahara unlimited the battery went dead, after I jumped it everything works fine except no radio. nothing at all lights up or comes on i changed the fuse which was a blue 15...
Is it the factory radio? If it is a replacement radio look for an inline fuse along the positive cable. Also wonder why the 15a fuse in in there if factory recommends 20a ? Perhaps someone was having issues before.
Last thought, if radio was on during the jumpstart it could have sustained damage.
1989 mustang dash lights wont come on but headlights still work and the factory radio wires cut when i connect the blue and red wires the dash lights come on but dont go off i dont understand it
Make sure the radio is wired up correctly,if it is then the radio it's self is causeing the problem.One way to find out for sure is to unplug the radio and see if the lights return to normal.
2answers
Jvc kw-nx7000 won't turn on
have you check all your power source
The screen will not come out and the unit will not play. The blue light comes on to switch from radio/cd/tv, etc. and the red light comes on when you push cd eject, but otherwise it will not play any
MAKE SURE YOU PRESS THE SOURCE BUTTON AS THE SCREEN WOULD NOT COME OUT FOR THE RADIO BUT WHEN PRESSED AGAIN WILL PROBABLY COME OUT FOR THE TV
1helpful
2002 Chevy Impala Radio Doesn't Work
Check the radio fuse? Box is drivers side end of dash(drivers door open)or pass side end of dash(passenger door open)
police models have a connection for the speakers (passenger floorboard under floor mat) to connect the speakers to the police radios.
If they had the speakers connected to their radios,they may have unhooked them and not connected them back to the radio.
The wires are brown,grey,blue and light blue.All into a blue connector.
4helpful
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Blue amp light lights for 2sec
bad head unit or look at your ground wire good luck
Bosch PB10-CD Radio/CD Boombox Logo
Top Bosch Audio Players & Recorders Experts
ADMIN Canada
ADMIN Canada
shibu tv
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
