Question about badoo Meet New People on Badoo
When someone sends me a picture it will not load even when i hold my finger on it for ten minutes
How to foward picture text to my email
You can send picture and text using email function to an email address.
Usually, with smart phone, you first open the picture. Then, you hold your finger on the picture and there will be a number of functions you can choose. One of them should be email. Choose the email function and continue to fill in the email address you are sending and put in your message in the Subject field. When you finish with them, you can press the Send button to send it out.
May 08, 2014 | Casio G-zone Commando
What should you do when someone has a nosebleed?
Sit the person down whose nose is bleeding and get them to bend their head slightly forward. Get them to pinch their nose just below the bridge and to hold it here for ten minutes. If it's still bleeding after that - pinch for another ten minutes. Usually most nosebleeds stop by themselves but if a nosebleed has gone on for an hour, medical treatment should be sought.
Feb 28, 2013 | Health & Beauty
Not Spinning LG WM2301HR
Steve R is right except that if the splines in the rotor are stripped you will have to buy a new rotor or the bolt will just continue to lossen itself up. The rotor is $64.33 online. Still a ten minute fix, after you wait a week for part delivery.
Jan 11, 2012 | LG WM-2077C Front Load Washer
When turning on our Barmin Nuvi 1200 it takes at least ten minutes for the navi to start. The screen just shows ; Loading maps.
You can try to reset the 1200. You can reset by pressing and holding the power button until it reboots.
If that does not work you can try a hard reset but it will clear out some of your favorites and saved locations back to like when it was new.
Power off the unit; then while holding your finger on the lower right corner of the screen while turning it back on.
Keep your finger pressed until a window appears. Choose YES to clear all data and return the 1200 back to factory settings. I will attach the Garmin customer support info.
Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 17, 2011 | Garmin nuvi 1200 Car GPS Receiver
Pressure on the EC65 is always high
Certainly sounds like a filter problem. Here's a couple of things to try.#1. i don't know how you cleaned the filters but clean them again with a good filter cleaner/degreaser.#2. After a good cleaning, get a bucket large enough to hold the filter fingers in and give them an acid bath. They recommend a 20 to 1 ratio of water to acid (muriatic) but I personally don' think thats strong enough. Use a good amount of acid and let the fingers soak for a good ten or fifteen minutes. (always add acid to water, not water to acid) Rinse and reassemble filter. If that does'nt solve problem, I think it's time to replace filter.
Jun 17, 2010 | Hayward EC65 Extended Cycle DE In Ground...
How do I reprogram the fax cover sheet? I bought the fax machine from someone and I would like to put my name on the fax cover sheet. I have a sharp ux-355L
While holding down the start and stop button with two fingers,
pull the plug from the wall, wait ten seconds, plug back into wall while still holding the two buttons, after plugged in take fingers off that should reset the fax.
Jun 06, 2010 | Sharp UX 355L Plain Paper Thermal transfer...
My canon faxphone l80 can not be loaded paper, once I load paper in the tray, the monitor still shown load paper
Please shut down the unit and remove all paper. Wait ten seconds turn the fax backon without paper. mAKE SURE THE FAX IS ONLINE. hAVE SOMEONE SEND YOU A FAX SO THE MACHINE DEMANDS THE PAPER. SEE IF THIS WORKS
Jan 19, 2009 | Canon FAXPHONE L80 Laser
Hi can you help /
You can try a master reset. With the unit off hold your finger on the upper right hand corner of the touch screen and tap the power button.  Continue holding your finger on the screen until you see a message "This operation will erase all waypoints, do you want to continue?" (this could take up to a minute)
Tap yes and the unit should reboot then attempt to acquire satellites.
Oct 09, 2007 | Garmin Nuvi 660 GPS Receiver
badoo Meet New People on Badoo Logo
516 people viewed this question
Top badoo Apps Experts
Zim Ali
Zim Ali
Level 1 Expert
Marvin
Marvin
NOEL
NOEL
Are you a badoo App Expert? Answer questions, earn points and help others
