Question about Sewing Machines
The stitch length is frozen on zero. was fine and i moved toward back stitch. It stopped and locked down at zero stitch length. Please advise.
Posted by rattlesnap on
R.A. Ellis
  • Sewing Machines Master
  • 12,731 Answers
Your sewing machine probably needs cleaning and oiling. Follow the instructions in your owner's manual and use ONLY recently-purchased good quality sewing machine oil.
Posted on Oct 13, 2015
The feed dog is up but has stopped feeding
Are the feed dogs moving at all--like moving toward the back of the machine, dropping down below the needle plate, moving forward, rising, and then moving toward the back of the machine? Make sure the stitch length is set high enough to actually move the fabric--not set at zero or near zero. If the feed dogs stay below the needle plate, then most likely they have been dropped for darning.
If the feed dogs are frozen, not moving, and it is an older mechanical machine, they may be seized due to old oil.
Wheel on right side that controls the needle up and down is very tight...
Or, the feed dog mechanism is broken.
Sep 01, 2017 | Sewing Machines
My Elna SU air has a cam stuck in the top. I have put oil on top and let it sit for hours but when I push down on the center post the cam will not pop up. What else can I do?
have you turned the stitch length and stitch width dials back to zero? this is important to disengage the "Feeler" arm which reads the Elnagraph where the disc is locked in. Turn stitch width to zero, stitch length to zero and make sure that the stitch selecter is on the "Disc" icon. Then press down ******* the metal centre button.
Dec 28, 2016 | Elna Sewing Machines
How to move feed dogs under needle for singer 514
First, make sure the feed dogs are in the up position and NOT dropped for darning.
Second, check that the stitch length is set to at least a 2 or 2.5 to make sure the feed dogs will actually move the fabric a noticeable distance. The closer the stitch length is set to zero, the closer together the stitches will be until it will sew only in one place because the fabric will no longer advance.
The feed dogs need to move. They should actually rise, move toward the back of the machine, drop down, move forward to the position to again rise--this creates one stitch. If the fabric is not moving, then it is possible that your machine has not been cleaned and oiled recently. Old oil will dry and cause the moving parts to seize.
It was working now it seems to be frozen the needle part wont move
Mar 07, 2016 | Singer Sewing Machines
When I try to sew, why doesn't fabric advance?
Either something is broken or the feed dogs have been lowered. This is done when using things such as automatic buttonholers and such. There is a level, usually under the plate, that lowers the feed dogs.
Feb 18, 2016 | Sewing Machines
How do I lengthen the stitch length?
Consult your owner's manual. On mechanical machines, there is usually a lever on the right side of the machine that slides from zero to 4. Zero will stitch in place, but the more you move the lever toward the #4, the longer the stitch will be. Usually, pushing the lever up above the zero will reverse the stitch.
On electronic machines, there is a setting on the screen for lengthening the stitch.
Dec 08, 2015 | Sewing Machines
How to remove a can from a elna Carina electronic 65
you need to set the stitch width dial to zero, the stitch length dial to zero so that the cam following arm is disengaged and moved back off the cam. Now look at the cam, it is sitting on a silver shiny spindle, press down onto this with your fingers and this will unlock the little finger which locks onto the cam, releasing the cam upwards. Press firmly and it should release.
Jul 03, 2015 | Elna Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
