Ovens Logo
Question about Ovens
I hava a diplomatic 920 double oven cooker and want to but another one just the same were can i get one from
Mister Danger
  • 5,631 Answers
Diplomat is produced by L.M. Electical and is sold through e-bay . I understand that its UK based manufacturer.
Telephone 01761 411111
Dyson Spares Washing Machine Door Seals items in ELECTRICAL store on eBay
Posted on Oct 11, 2015
1helpful
Just moved and have diplomat built in single elec oven checked inside but cant find model or serial no. 2 knobs on left all symbols gone some push buttons middle and knob on right numbered 1 to 5
Hello -
Please double check for the model number. It will probably be on a small metal plaque on an edge of the oven door, along the outer edge of the oven opening, or in the oven interior. It could also be on the top of the oven and covered by cabinetry.
Undo the screws that hold the oven in and slide it out 6 inches. You may then find the metal plaque on the top of the oven. You may need the help of another person when you try to pull the oven out, so that the oven does not tilt forward and fall to the floor.
You MAY be able to identify your model of Diplomat oven from one of the images of Diplomat oven control panels here:
https://manuall.co.uk/diplomat-select-620-oven/
Page 6 (PDF document image 7). Note: Use the + icon to enlarge the image.
You may find the image of Diplomat oven knob markings here helpful:
https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/cooker-and-oven-forum/61498-diplomat-adp4890
Scroll down that page to the post dated 14-12-14 from pslewis333 to see the image.
Once you know which model of Diplomat oven you have, you may be able to find and purchase decals with the proper knob markings for your oven so that you can affix the decals around your oven knobs. Or, you could use heat resistant paint and a small, pointed paint brush to paint the markings on your oven. With either option, I suggest you seal the markings with a heat resistant clear sealant so that cleaning / scrubbing will not erase the markings.
Best wishes.
Jan 24, 2019 • Ovens
Diplomat elite double oven. No manual.how do I set the clock.
Hello -
Apparently, the Diplomat brand of ovens ended production in 2008.
Prior to the end of production, Diplomat was part of the MFI company, with the company's Hygena brand name combined with Diplomat.
I have not yet found a user manual for Diplomat Elite Double oven online.
However, I have found a Hygena Diplomat manual online (free) and the manual has instructions for the clock. The instructions MAY be the same for your oven (I hope.)
See:
https://productmanuals.inbro.net/seeinsidebrochure/Product-Manuals_Hygena-Diplomat-Select-Ovens/Hygena-Diplomat-Select-Ovens/page_1
The clock instructions are on Page 10: Using Your Electronic Minute Minder.
Best wishes.
Apr 07, 2018 • Ovens
2helpful
2answers
I have moved into a property that has a diplomat cooker. I am looking for instruction booklet for it can you help
Diplomat are no longer trading. These appliances where fitted with MFI kitchens who have also gone
Oct 19, 2009 • Ovens
2answers
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
1helpful
Hi need a manual for a select 920 diplomat oven
I have a Hygena 920 twin oven and grill .The electrical element in the grill started to droop several months ago, now it has stopped working . the element has burnt through. Could this have caused a fire?
I should like to know if it is possible to get a spare element and fit it myself. What would be the cost of the element? Thanking you in anticipation.
Mr J. Walden
Sep 02, 2009 • Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
I need to change a cooker lightbulb
You should just be able to pull the cover off tords you if it is flush to the serface or you might have to unscrew it. Try thouse things first.
Dec 16, 2008 • Ovens
2helpful
2answers
DIPLOMAT SELECT 920/AHY4401 S/S OVEN MANUAL
I have a copy of the Select 920 double oven instruction manual. Send an email to [email protected] and I will reply with a copy in .pdf file format.
Dec 24, 2007 • Ovens
Top Ovens Experts
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
