Question about Jacuzzi Home
I have a Espree 536 and need to replace the magic air switch. The tub is enclosed with a tile mosaic front which I do not want to have to remove if at all possible to replace the switch.
Can the magic touch switch be replaced from the top of the tub?
Posted by Susan Haddock on
Bill Boyd
    Top Expert:
  • Jacuzzi Master
  • 53,816 Answers
It is possible that the switch is held in place by a nut from underneath
see if you put your hand up under the panel to see if there is a nut there
Posted on Oct 11, 2015
Jacuzzi majic touch won't turn on
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Nov 28, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
We have a 1996 built in Magic Chef dishwasher which is now not completely cleaning the dishes. There is always some residue left on most dishes, glasses, silverware. I rinse everything before putting them...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Jun 28, 2011 | Magic Chef Dishwashers
I have the Civa Jacuzzi installed with the Whirlpool magic touch on/off switch. It was purchased in 1994. Where can I get the same replacement switch?
Possibly here...
http://www.jacuzziwhirlpoolbath-parts.com/bath/bath0034.html
I am looking to purchase a used Civa. How do you feel about the tub in general?
Feb 16, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Espree 7242 pump/motor will not shutoff. Manual says to reconnect tube to Magic Touch switch or to air switch pumpmotor. Do I have to pull the tub out? It sits in a tiled skirt.
There should be a removable panel either around the skirt or in the ceiling below the tub to access electronics and plumbing to repair.
Jan 09, 2010 | Tools & Hardware - Others
Tub does not spin but agitates
Sounds like the door switch is either loose or faulty. The door switch keeps the tub from spinning with door/lid open.
Charlie
Aug 21, 2009 | Washing Machines
Machine not spinning properly
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components. Enter your model number into the PartDetective on the Find & Order Parts page to see all the parts available for the unit.
Go here for Magic Chef Washer Parts: http://www.repairclinic.com/Magic-Chef-Washing-Machine-Parts
www.RepairClinic.com
Jan 25, 2009 | Magic Chef CAV2000 Top Load Washer
No access panel and need to reconnect the vacuum hose
The trip lever is an over flow for the tub to prevent you from over filling the tub capasity and flooding your home.
Mark
Dec 24, 2008 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
Home Logo
396 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
