Question about Dell Inspiron Computers & Internet
SOURCE: Flashing lights
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
Posted on Apr 24, 2008
SOURCE: wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Posted on Dec 18, 2008
SOURCE: Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Posted on Jun 29, 2009
