Question about ASUS ZenPad - 7.85" - Intel Atom - 32GB
I want to remove password from my tablet but it says that is it disabled by administrator, encryption policy, or credential storage.
Alexandria Smith
    New Friend:
    Problem Solver:
  • 17 Answers
Try looking up "control google dashboard' on browser.
Posted on Dec 13, 2017
Correct credentials needed to sign into gamail account on my tablet only. Smart phone is okay. I do not need to physically sign into the app just click on it
Please clarify what you need.
Your question makes no sense.
What "credentials" do you need?
A User ID?
A Password?
Some input necessary for your tablet?
What tablet is it? iPad?
If you are logged in to your Gmail account on your smartphone
you are logged on to every device you have listed
with Google.
Have you registered the tablet with Google online?
Is it your tablet, or are you trying to access someone
else's tablet.
Aug 22, 2018 | Tablets & eReaders
How do I remove demo mode off my tablet
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message.
Mar 26, 2015 | Acer ICONIA Tab A500 10.1 inch Tablet PC,...
Why does my table ask for password to decrypt storage?
because you setup the tick box to encrypt the storage
Mar 11, 2015 | Nextbook Premium 8 Se Android
Hi I got a Ultimate 7 inch tablet. I reset it and now its asking to type password to decrypt storage. I don't know what password it wants. What do I do.
A user of the device has deliberately turned on data encryption to protect the contents of the device in case of loss or theft. I say deliberately, because you have to enter, then verify, the password, and then agree to the encryption. If you don't have that password then you are going to have to perform a factory reset of the device.
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button.
Go to the option for Factory Data Reset and select it. Scroll down to Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
Feb 02, 2015 | Tablets & eReaders
I have forgot my password for my samsung galaxy tab 3
1 problem is I cannot verify that you really are the owner of this tab. But you should be able to do a hard reset by a turning off the tab, holding the power, volume up and home button all at the same time until it resets.
Jan 07, 2015 | Samsung Galaxy Tab Tablet PC
I have a proscan tablet plt7100g my grandson did something to it. now theres android saydassword decrypt sytorage on it
A soft-reset won't work. Someone turned on the encrypt storage option, so the proper password needs to be supplied for it to work.
Unfortunately once a password is set you can't use the device without it. You need to do a Factory Reset (which will wipe all data and settings) for the tablet to otherwise work.
How to do factory reset on Android CNET
Jan 03, 2015 | Tablets & eReaders
Yahoo Password
its save but most likely encrypted and I doubt you cannot read that.
Oct 07, 2013 | HP 9.7 Touchpad Tablet, 1GB Memory, 32GB...
Password
Hi, I'm not sure if there is a universal password, but if you can remember the Pin number try the following steps.
Power your device off, and then start it up again and enter the correct pin number. If that doesn't work, you will need to try the option to enter your Gmail account credentials so that you can access your device and change your password. (Oh, I forgot you can't access your Tablet)
I think you will have to do a Hard Reset by completing the following steps:
Turn off Tablet Try one of these key combos (each Android device uses a slightly different key combo, but these are the most common).
Volume Up + Home + Power or Volume Down + Home + Power
or
look for a reset button/hole
Release the power button when you see the Android
Choose recovery mode
Choose wipe data/Factory Reset
Choose yes
Tablet will reboot or will ask you to reboot
NOTE: This procedure will delete all apps and data so use it as a last resort.
Good luck
David
Feb 25, 2018 | Tablets & eReaders
I have a Kindle (wifi version) and can't connect to my network. I have a wrt54g linksys router. do i enter my router password or my wpa shared key? I've entered my router password many times and it...
You have to enter the WPA share key. The router password is only to access the built in administration web facility. The WPA share key is the encryption key necessary for the Kindle to connect to your router.
Jan 02, 2011 | Amazon Kindle Wireless Reading Device
Disable BIOS Administrator password
Enter BIOS SETUP. Enter the current password.
Change it to a "blank" password.
Or, if you don't know the password, find the orginal sales-receipt, to prove to HP that you are _NOT_ a thief in possession of the stolen computer, and then HP will assist you.
Aug 24, 2010 | Compaq 2710p Tablet PC
ASUS ZenPad - 7.85" - Intel Atom - 32GB Logo
61 people viewed this question
Top ASUS Tablets & eReaders Experts
Terry
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
