Question about iRiver T20 MP3 Player
Iriver T20 not recognized
Hi the problem is when i connect the iriver T 20 to the usb port the system dispalying the message as unknown device. it worked good previously. how to solve this.
  • 1 more comment
  • klaas1 Jun 24, 2008
    When I connect the iriver T20 fm MP3 player, it says it is connected (through the USB-port). But Windows XP says that it cannot start the divice (code 10). It recognizes the device just as an MTP-device, but not as an iriver T20 (like the manual says). What happens then is that de player is fixed in the USB-connected mode and doesn't work at all. Only when I wait untill the battery is empty, and load it again, it will work again. I tried the give tip to hold on de volume + button, reconnect the player on the computer and hold de volume + button for 5 - 50 seconds. But nothing happens. So now I'm in trouble, because I cann't change the music anymore. The help-desk of Iriver didn't react on this problem, so who can help me?
  • hirdy Aug 14, 2008
    When the Iriver T20 is plugged into the USB port windows xp says the USB device is not recognised,I've tried holding the volume button as previously advised in a previous post
  • mauricioespi May 11, 2010
    ThaMp3Doctor
    Hi man .. I've tried your trick but nothing happened ....just same as always "unknown device" .... i went to control panel\system\hardware\usb port\unknown device ....and reinstall driver but ..nothing happened.
    What about making a short on Chip pins ?? inside the unit ?
    Sometimes work on other units.... but i removed the screws under golden frame on iriver ....but still stocked there ...is almost impossible to open .
Download this software and do a recovery - helped me !
http://www.iriver.com/support/down_view.asp?idx=736
Posted on Jul 24, 2008
  • 8,597 Answers
Try this: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
All the info/manuals/drivers/upgrades for the iRiver T20 can be found here:
http://www.iriver.com/product/p_detail.asp?pidx=71
Posted on May 23, 2008
How to fix iriver E10 it says on the screen is emergency usb
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 22, 2011 | iRiver E10 Digital Media Player
Does not open the iriver E10
USB port gives new message "unknown device"
hello allan213
my name is ausi.
is it on all usb ports only one of them if it is in only one of them then the message you getting generaly means one of thw follwng.
1- if it is in only one of the ports then try it with a different device as well to see if it is the actual port or not.
2- the device you have plugged in needs to have drivers installed. normally should have been supplied with it.
3- the device you plugging in is faulty and the system can not access it.
4- the system usb ports are overloaded. (too many usb devices connected simultaneously)
good luck
Jan 05, 2011 | Intel Motherboard
I have an Averatec model#3150p pc notebook.It has a 3 port usb hub but only 1 port works. i.e.:When I plug a device into the 2nd or 3rd port I get error message saying the device has a problem.(unknown...
Dear Friend..
Go to Control Panel=>System => Harware=> Device Manager. Under the "Universal Serial Bus Controllers" delete all USB root hubs & controllers/ ports & then Action=> San for hardware changes That shall freshly install the USB ports on your system & shall work.
Best of Luck..
Jul 10, 2008 | Computers & Internet
Iriver e100 doesn't communicate properly
umm.. this is what i did to solve this problem. i hooked it in the back usb port then put the iriver disk in then went to start control panel printers and other hardware the on the left side add hardware the i found it on the list and instaled after that you have to use windows meda player to add music and it works just fine .
May 20, 2008 | iRiver E100 Digital Media Player
Black screen
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Jan 17, 2008 | Canon PowerShot A540 Digital Camera
Iriver T 20 not recognized.
All the answers/drivers/manuals for the iRiver T20 can be found here:
Dec 28, 2007 | iRiver T20 MP3 Player
Conectivity
Dec 21, 2007 | iRiver T20 MP3 Player
Buffalo USB 25gb external hard drive
There is probably just a bad connection between the usb and hard drive. Unplugging it and plugging it back in. If that doesn't work try another usb port. That usually fixes the problem.
Aug 23, 2007 | Buffalo Technology (DHHSD10TGLR5) 250 GB...
IRiver MP3 Player Not Inisializing
If you haven't already I would try an emergency connect. -First perform a standard reset as you did before (press rear button for 20GB or disconnect & reconnect the battery for the 5/6GB versions). -Leave the unit turned off, but connect it to your computer's USB port. -Hold down the "o" button and then press the power button for a second to power on the device. -Do not release the "o" button until you see a message such as "emergency connect" or "mass storage" on the player screen. I beleive the message has changed with firmware versions, but it should be something similar. -If this works it should be detected by your computer as an external drive. You should have access to the files. -I would remove all music files from the device and then use the iriver plus software to restore system files. -If you manage to get to this point I would install the newest firmware available for your model of H10, found at the iriver site. The newest firmware adds a lot of functionality, speeds up player response significantly, and fixes many bugs as well.
Dec 03, 2006 | iRiver H10 MP3 Player
iRiver T20 MP3 Player Logo
633 people viewed this question
Top iRiver Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Zaid Anarwala
Zaid Anarwala
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
