You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
You can try to re-build the operating system with the original disks. You can get a new hard drive and reinstall the OS. You can boot to Bart PE or other type of system disk to investigate the cause of the crash and try to repair it.
The replacement drive is not the same size as the original and the wizard is looking for a drive that size.
There is also a possibility that the error is causes by bad RAM (0A-0543-0000 is a read write error) if you have more than one RAM module try the wizard with one module at a time, see if error is isolated to one or the other module or slot
The Restore CD is dirty/scratched of has a flaw in the original write
The optical drive is defective or dirty
So things you can try:
Clean the media you are trying to restore from.
Clean the optical drive with a drive cleaning CD.
Swap Ram as suggested, replace defective if necessary (OS install is about most RAM intensive process you run on a system)
Try a manual Windows install from a Windows CD not a image restore cd
Run your bootable OS CD and then run the option of repairing the existing OS. All the original files will be replaced with the correct system files and you should get the same looks as it was, originally...................sodeep
The recovery disk is usually stored as a separate partition on the hard disk itself (Mostly in cases of laptop disks), so when ever you purchase laptops with pre-installed Operating System, The very first thing you do is create a CD/DVD recovery disk ie burn the recovery partition on the CD/DVD. so that you can use the same DVD in case the OS crashes. In your case as your hard disk was crashed and replaced ask the people from where you purchased the laptop/pc to restore it to the new hard disk, or purchase the Operating System.
Always get the original manufacturer's drivers directly from their website. Be sure to select the correct Operating System (like XP or Vista or Mac OS). Canon CanoScan 4400F Drivers
