Window switch or door locks
Which window switch ?
RT DOOR CB-circuit breaker , do you know what a circuit breaker is ? 25A (System power for right rear window)
LT DOOR CB 25A (System power for left rear window
The power window system will operate anytime the retained accessory power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The DDM contains 4 power window switches which are integral components. Closing any of the normally open, rocker type switches provides the DDM with a request for power window operation. The switches for the 2 front windows have 3 positions Up, Down and Express Down, while the switches for the rear windows have only 2 positions, Up and Down. Each of these switches and their positions is a direct input into the DDM. Upon receiving a request for power window operation, the DDM, transmits a class 2 message indicating the switch and it's changed position.
The PDM contains a single power window switch that is an integral component. Closing of this normally open, rocker switch provides the PDM with a request for the front passenger power window operation. The switch for the front passenger window has 2 positions Up and Down. Each of these switch positions is a direct input to the PDM.
The 2 rear passenger doors have there own switches. Each of the switches contain a power window up and down relay. A switch activation alone can control the up and down functions of the rear windows. However the BCM, upon receiving a class 2 message from the DDM, can control the set of relays which will activate the rear window motors.
The power window system consists of the following components:
Driver door module (DDM)
Passenger door module (PDM)
Body control module (BCM)
LR power window switch
RR power window switch
Window up and window down relays in each of the rear passenger window switches
Window lockout switch
Reversible power window motors in each of the doors (circuit breaker protected)
LT DOOR CB 25A (System power for left rear window)
RT DOOR CB 25A (System power for right rear window)
If you not sure about any of this I suggest you take your vehicle to a ASE certified repair shop .
SOURCE: power door locks and windows
i would chk. fuses there should be one, if not in fuse box in car then under hood. if fuses are ok then i would say its the master switch on drivers door thats bad.
SOURCE: power door locks and drivers window have failed on 2004 colorado
I had the same problem to the T. I look online for all the same solutions and I can only tell you what worked for me. Actually what I think worked, HAHA! I went out to my truck and unplugged both battery terminals from battery and placed them together to supposedly reset the electrical system, "so I was told." After this for about 20 min or so, I went back out and in this order; re-installed positive terminal followed by negative terminal to battery. After this I checked locks and windows and surprise they worked. I've seen a lot of people say that all they did was wait and they worked later, so maybe it was that and not what I did, but who cares, they work now. Give it a shot and if it works for you, GREAT let me know, I HATE CHEVY CAUSE OF THIS......they wanted me to pay for a stupid diagnostic before they would help me........well screw you I fixed myself. LATER
SOURCE: no power to passenger door window or lock, drivers
I know this sounds strange but I believe the problem is in the drivers door. This is where the master switch is and controls the other doors. Have it tested or replaced. Hope this helps. Good luck.
SOURCE: 2005 Chevy Colorado drivers side window, and power locks
Check for door ajar switches not making contact.
SOURCE: door locks and power window
Just did this procedure I got from coloradofans.com forums:
"any type of power/voltage change
seems to trigger this issue
The most common symptom is power
locks fail and only the driver window quits, however that is on the
extended cab.
Steps to fix and it works every time.
take
door panel off driver's door
Disconnect the wiring attached to window
and power lock control unit
disconnect battery cables
connect
the negative to the positive cable(((NO BATTERY CONNECTED)))
This
will act to short residual voltage in the system
5 minutes later
place
the key in the ignition and turn to the run position
connect the
wiring to the window/lock controller
connect the negative cable to
the battery
then the positive
open drivers side door
turn key
to the off position((do not remove yet)) you should get a series of
dings through speakers telling you the key is still in the ignition
once
it begins dinging pull the key out and you should hear the door lock
solenoids trigger and the windows should work." - Coloradofans.com forums
Are you talking about the master switch on the drivers side?
its a police interceptor cant open the rear door with the switch on the door
