Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
I replaced the regulator and now the machine does not turn on correctly; it stays in the green blinking mode and no water flushes through the machine. Why? How can I fix it?
The machine is 5 years old and I decalcify it regularly when it requires it.
Posted by Enrique Trujillo on
  • Enrique Trujillo
    Enrique Trujillo Oct 08, 2015
    Thank you Scott and Mark for your suggestions. I have run the hot water dial and hot water is running fine, no air seems to be in the line? As for the pump needing replacement, the machine was working fine prior to replacing the generator other than the water leaking inside from the old, corroded generator. However now the water leak is fixed with the new generator but now the machine does not turn on correctly. If I leave the machine alone while trying to start up, the green 1-2 cup lights remain blinking for 8-10 minutes until the triangle red warning light comes on. You hear the defuser moving but nothing else. Once the warning light comes on, I have to unplug in order to be able to turn on again. Here is the weird outcome, if I turn off the machine 2-3 mins into the green lights blinking, and immediately turn it back on, the machine goes right into use mode and I can make coffee fine? I don't know if it is the new generator not compatible? I purchased it through eReplacementParts.com and it comes up as the correct part under the model number I own??? Any suggestions is much appreciated. Thank you
2 Related Answers
Anonymous
  • 133 Answers
SOURCE: Not brewing
it sounds like the pump inside is bad, from either a clog or fuse perhaps.the pump sends the water thru so thats the likley problem.
Posted on Sep 15, 2007
mnwarfield10
mark warfield
  • 452 Answers
SOURCE: I own a Delonghi EAM3400 Expresso Machine that has
turn unit on ...switch on ... turn water steam control to open position ,,,,,it should sound load then go quite as air lock will come through .. hope this works if not i repair you need spares .. ..postal service too 07779933829
Posted on Feb 23, 2011
RANDOM leaking from top back of toilet when refilling water after flushing.
sounds like regulator set for too much water to refill turn screw on reg to close aperture to trickle of water after flushing and adjust accordingly for flow of water to just fill level or just below regulator
Mar 22, 2015 | Cars & Trucks
My computer screen goes black and stays black unless in safe mode.
does the power indicator turns from green to red then does it blinks?.
Oct 15, 2012 | E-Machines eMachines Monitor E15T4
On the spin cycle setting, should the green light be blinking all the time through the whole wash load.
It blinks when you have spinsense mode activated. When you first start a load just press and hold the water plus button for 3 seconds to turn it on and off. I'm honestly still not sure what exactly the spinsense mode does but thats all it is so nothing to worry about.
Oct 03, 2010 | LG WM2016C
I can not get out of descaling mode. I turn it of, unplug it, went into programing mode. Is there a way to reset it? Thanks
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
Jul 17, 2010 | Gaggia Syncrony Compact Coffee...
Got the tv stanby Working
The ribbon connector which goes from the FMT to the DM is disconnected or not seated properly thats the only thing that will cause the 4 4 error other than a broken ribbon socket
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My WD-52825 wont turn on and its not the lamp....
If you want to have it repaired email me at [email protected] i have repaired over 200 of these sets. I have been a professional electronics technician for over 40 years. email me for details and pricing. beter prices then mits or pts
Nov 05, 2008 | Televison & Video
After descaling stuck in infinite loop
How old are your machine?
How often do you descale the machine?
I think it can be the flowmeter in the machine that needs to be replaced.
Try to descale the machine to see if it help.
Best regards
/Mirran
Sep 07, 2008 | Saeco Caffe Charisma Espresso Machine
LED Blinking
Okay 2 blinks isnt a error code, so your set isnt shutting down due to a protection issue, so I would suspect one of the low voltage regulator transistors or the horizontal output transistor as being defective
Jul 06, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
190 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
