My LCD Projection television, I'll have a picture on the television and then the television goes blank with a green light flashing for about 30 times & then the picture will return.
We've unplug the television for 5 minutes. The picture bulb light is still on even will the picture going out & rebooting.
Since you say that there is sound but no picture, the first thing I would check would be the status of the lamp. I believe that the lamp has been shattered or the filament is blown. Please verify this and let me know
The LED light "LAMP" indication stay on or flashes in this problems?Yes,the projection lamp is the causes and problems.Change the projection lamp,should solved the problems.
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
helloFive blinks - AKB circuit (automatic kine bias), the
timer/standby indicator blinks for about 30 seconds then goes to the
self-diagnosis function. Something is wrong with the video. Check video
out, Q705, 732, 761 and other components on the C board, also check
Q218, 219, 220 on the A board. In addition, unit could be in IK
blanking, try turning up screen slightly.
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
