Question about Lands Phones
My landline has a dial tone but I can't call out, as dial tone continues-do I need a new phone?
Posted by Donna Hardin on
Andrew Taylor
    Top Expert:
  • Lands Phones Master
  • 33,363 Answers
Look on the side of the phone for a slide switch for Tone and Pulse dialling. You need Tone.
Difference Between Tone Dialing and Pulse Dialing Difference Between Tone...
Posted on Oct 07, 2015
  • Thomas Burke
    Thomas Burke Feb 28, 2016
    very good definition of pulse and tone dialing. Thanks
  • Andrew Taylor
    Andrew Taylor Feb 28, 2016
    did it fix it?
Panasonic DECT 6.0 cordless phones system has begun dropping calls after first ring also won't take messages
Firstly, disconnect all devices / base unit from your landline. Then, using a mobile phone, dial your landline number. Does the ringing tone in the earpiece continue or does it stop after one ring? If it stops then you have a line problem which you need to report to your service provider.
Apr 27, 2017 | Panasonic Lands Phones
Chat to customer agent landline reported to faults still not repaired
Where I live, my landline company is responsible only up to a "demarcation point" - this is a box on the wall near where the phone line enters the house.
There is an RJ11 socket on the box,
chat-customer-agent-landline-reported-2iujiwfvuy020nygunv3yc1j-5-0.jpg and the technician (or you) plugs a known-working phone into the socket, and listens for a dial tone. If there's no dial tone, then the tech takes corrective action - replacing cable, or confirming correct operation of the distribution box on the boulevard / utility pole, or contacting billing to reactivate the line.
If I dial 611 from my or a neighbour's landline, they'll typically have tech to my door in 24 hours.
Beyond the 'demarcation point' (ie inside my house), it is my responsibility to ensure the internal phone wiring is operational.
Check your local thrift stores for a replacement phone, if necessary.
Your local hardware store will likely carry a 'tone & probe" set, which will indicate if a phone socket is wired properly, and can be used to follow a wire through walls / ceilings / floors.
Pro3000 Analog Tone and Probe
Mar 17, 2015 | Lands Phones
NO dial tone
Verizon may have shut down your phone line because it needs service. This should be reported to Verizon repair by using your computer.
Jan 07, 2014 | Lands Phones
How do i forward a call to a cell phone?
I believe your landline carrier just needs to have the capability of call forwarding (ie we utilize Verizon for our business). We also use the call forward feature by: picking up line, (hear dial tone) dial *72 [ then phone number you want calls to forward to, even a cell]. To discontinue: pick up line (hear dial tone) dial *73
Mar 02, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Will not dial out on landline in the tone mode but
There's something wrong with the base unit that connects to the phone line. It's not sending any audio to the phone line, which would explain why tone dialing doesn't work and people can't hear you. (Pulse dialing doesn't need the audio tones so it will still work.)
I've never run across one doing this before. The problem is almost certainly some electronic failure, and I doubt there's anything you can do other than replacing the thing. If this is still under any warranty it should be up to the manufacturer to repair or replace it. If you got this from VoIP service provider, contact their customer service department.
Feb 03, 2010 | Philips VOIP3212G/37
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
My at&t landline has a dial tone but cannot call
check dialing mode matches what exchange is set to DTMF suspect phone is set to dec = decadic or pulse
Apr 17, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Lands Phones Logo
408 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
