Question about Kodak EasyShare LS443 Digital Camera
Do I need a different cord for both camera and charging dock ?
I need a charging cord for my charging dock or do I just need to purchase a charging cord for my camera ?
4 Suggested Answers
Anonymous
  • 2985 Answers
SOURCE: Camera Dock is not charging camera
Camera or battery dead.
Posted on Jul 31, 2007
wayneard
Wayne Mineard
  • 1901 Answers
SOURCE: charging my camera on dock z8612
According to Kodak Support your camera is compatible with a Series 3 Camera Dock.
For future reference, here is the support page for your camera that has a lot of information available.
Z8612 Support
Thanks for using Fixya.
Posted on Jun 08, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: Printer Dock Series 3 broken
KODAK still repair your product: OoW repair price: 48,44 pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 13, 2009
Anonymous
  • 262 Answers
SOURCE: I have a DX7590 that won't charge the batteries.
Jeff, you didn't verify the type of battery that you have on your camera, is that the KLIC-5000? if yes then still it will not charged on your dock try to charged your camera using the 5V AC adapter. If your camera will not turn on using the 5V AC adapter or will not turn on using your dock it means the camera is defective and not your battery or charger. You can still contact Kodak repair center at 1 800 665 6515 they will handle your issue.
Posted on Feb 09, 2010
Can i charge with USB cord to dock and comp
Fuji FinePix Z2 Digital Camera
lens retracts fully into the body and is protected by an automatic metal cover - no more lost or dangling lens caps.
The F410 Zoom makes use of the new xD-Picture Card media that is smaller than a postage stamp. Fuji supplies a 16MB card and they are available now up to 256MB. The F410 is powered by a small proprietary lithium rechargeable battery. This battery pack performed well in our use and if the color LCD is used sparingly, I see no problem with the battery delivering enough power for a conservative day's use. As with any camera that uses a proprietary battery pack, it is always a good idea to purchase and carry a charged spare at all times. The included power supply / charger is an auto switch type and operates on 100-240V AC which is convenient when traveling. It charges the battery in 3 hours (or less) while in the camera and also functions as an AC power supply for extended use at home. The battery is also charged any time the camera is placed in the optional camera dock.
Dec 02, 2012 | Fuji FinePix Z2 Digital Camera
Dell duo station
I had the same issue. I tried opening the dock and could not find anything wrong. It seems the charger was delivering sufficient voltage. So I disconnected power to the charger and reconnected couple of times and it started working again. My charger has a LED light and based on the brightness of the light you can findout if the output voltage is close to 20 volts.
Sep 20, 2012 | Dell Jbl Inspiron Duo 1090 Audio Station...
When you buy a m753 kodak does it come
Kodak sells three different package versions of their cameras. You can purchase one of their cameras with an adapter but no dock, with adapter and dock, or with adapter and printer dock. The dock and printer dock are also available on line (try eBay) as accessories. The dock is an extremely handy accessory, allowing automatic charging and computer connection. The printer dock though, at least in my experience, is a cumbersome and unreliable method of obtaining low-quality photos.
Nov 07, 2009 | Kodak Easyshare M753 Digital Camera
Batteries will not recharge on Kodak EasyShareDX4330 Camera dock seems to be working fine otherwise.
if your are using the ordinary AA rechargeable battery it will not charge., Camera dock will charge only on a 2 Pack AA battery like KAA2HR batteries or the 2 AA battery that attached together (Ni-MH rechargeable battery pack )
What type of battery are using?
try to purchased KAA2HR
Nov 05, 2009 | Kodak EasyShare DX4330 Digital Camera
Can kodak CX7430 be charged with USB
A USB connection will not provide sufficient power to your camera and it could damage the internal board. You could opt for purchasing a AAA battery charger or buy a charger/ac adapter from eBay as they go around 10$. The model you're looking for is kws0325.
Good luck.
Sep 06, 2009 | Kodak EasyShare CX7430 Digital Camera
Vivicam 5340s camera dock
You can't charge the camera with the USB cord because the camera dosn't have a charger built inside. You need to use an external charger. Here is a link showing several sites that have battery chargers for this camera.
Dec 26, 2008 | Vivitar ViviCam 5340s Digital Camera
CasioEX-S880 will not charge.
Hey ITDude,
You do need to charge the camera by putting it in the camera dock and the ac cord should be plugged into the camera dock. It is possible that the battery has gone bad so you could try getting a new battery. If neither of these options work I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 18, 2008 | Cameras
When I put camera on docking it win,t show charge
First, the dock will charge only the batteries that came with the device; not other rechargeable batteries.
Be sure that the Kodak battery is inserted correctly, the door is closed securely, and that the camera is securely seated in the dock with the power cord secure to both the dock and the AC outlet. The USB cord does not supply power to the dock.
Hope this helps.
DigiChick
Jun 09, 2008 | Kodak EasyShare CX7330 Digital Camera
Charging Battery
maybe your battery is dead, put your battery in your freezer for one night and charge it again.
Jan 21, 2008 | Video Cameras
Battery/Docking Station
I have a working used one if you're interested. Google my username, and I can help out... ;)
Jan 11, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Kodak EasyShare LS443 Digital Camera Logo
55 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
