If the following doesn't work the
tubes could be at the end of life:
Adjusting convergence:
Note: For best
results, the Projection TV needs to be turned on for 15 minutes or
longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
- Press the 'MENU/SELECT' button on the remote.
- Press CURSOR RIGHT to enter the PICTURE menu.
- Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
- Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT
and DOWN to select CONVERGE BLUE.
- A crosshair will be shown on the screen. If there is any red or
blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to
try and merge the fringe colors with the crosshair.
- Press the 'MENU/SELECT' button to return to MANUAL CONVERGE
menu.
- Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now.
Otherwise, you can continue and adjust the convergence more using mult
ipoint convergence.
To Adjust multipoint convergence:
- Use CURSOR RIGHT to enter the PICTURE menu.
- Use CURSOR DOWN and RIGHT on the cursor ring to select and enter
MANUAL CONVERGE.
- Press CURSOR RIGHT and DOWN on the cursor ring to select
MULTIPOINT RED or MULTIPOINT BLUE.
- A grid of crosshairs will appear on the screen. If there is any
red or blue fringe around any of them, press CURSOR RIGHT to enter
NAVIGATE mode.
- Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that
has a color outline.
- Press the 'EXIT' button to enter ADJUST mode.
- Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the
crosshair.
- Press the 'STATUS/EXIT' button to return to NAVIGATE mode.
Repeat as necessary.
- Press the 'MENU' button to return to the MANUAL CONVERGE menu.
- Press CURSOR DOWN until SAVE MULTIPOINT is
selected.
- Press CURSOR RIGHT to save the multipoint settings.
