Question about Olympus m:robe MR-500i MP3 Player
M:trip not responsive to m:robe
Everytime i go and plug my m:robe to my laptop the computer detects its there but m:trip doesnt??? so whats wrong with my 500i??
Posted by Leviboi on
  • xWrist Nov 15, 2008
    In the services tab of msconfig it says that MrobeService is 'stopped' although it is checked; how do i make it 'running' because i can open and run mtrip?? cheers
Anonymous
Mine did that to me a few times. One thing you could try is to make sure the driver is activated. Do this by using the start menu and clicking run. then type in msconfig. the go to the tab services, and make sure the program Mrobeservice is checked and running. Hope that helps!
Posted on Jun 30, 2008
Hi. My name is Natalie. I got an m:robe for my 16th birthday at MTV'S TRL. Today, I just plugged this in to my computer and i deleted songs, put some in, and now, its saying INVALID/MISSING FILE. After you...
okey..try this..i got the same problem and i managed to rectify tht using this method..check it out anyway...first of all try to format your player in ntfs filesystem and http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index extract the files to your player and then
install the m:trip software from
http://downloads.olympus-europa.com/consumer/mrobe/m-trip/ENG/mtrip_english.zip
after tht install the firmware http://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..before installing the firmware make sure tht u reset the player ..after following all the instructions of the firmware try to synch the player to check whether it detects music and finally restart your m:robe to take effect..!!
Computer wont install the software
Don't plug the mp3 player into the computer until you install the software
Olympus mrobe
unzip it, drag the System Folder and the Index.mum filedirectly onto your m:robe. then pull it off the dock. you might have topush reset.
and then freshly install the m:trip software from
aftertht install the firmwarehttp://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..beforeinstalling the firmware make sure tht u reset the player ..afterfollowing all the instructions of the firmware try to synch the playerto check whether it detects music and finally restart your m:robe totake effect..!!
Olympus m:robe 100 missing file
18helpful
5answers
M:robe error invalid/missing file
hello, i had the same problem. recently, i had deleted all the files off of my mr-100. i downloaded this file.
Once you unzip it, drag the System Folder and the Index.mum file directly onto your m:robe. then pull it off the dock. you might have to push reset.
i couldnt get the "invalid/missing file" screen to go away for a while. if you slide the hold button into the hold position and then push the little reset button on the bottom, it will remain off and you can put it on the dock, then it will connect to the PC.
Blank Screen
Try pluggin in the USB cable and plug it in. if this works, re sync with m:trip
Its probably a problem with the HDD (hard Drive)
2answers
Sync problems
hmmm, sounds like you need to check if the device is installed to use with the m:trip software.
if it is, then try refreshing the program and the device.
if this doesnt work, then you may need to seek proper help.
hope it works.
Olympus m:robe MR-500i MP3 Player Logo
Top Olympus Audio Players & Recorders Experts
Richard Schabler
KBeaN1
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
