Question about Riccar 8850 Vacuum
My Riccar 8850 is very hard to push, even moreso on heavier pile carpet. Know any reason why? Also see my "more details" section.
Belt was replaced, new bag is in, nothing is wound around the brush. Brush spins, plate is correctly installed. I simply don't know what is wrong. I recently had the carpets steam cleaned ... noticed the drag on the vacuum after the cleaning. I assume this is because the carpet cleaning re-fluffed the carpet. Any ideas on what is going wrong?
Posted by Cheri Soliday on
Bill Boyd
    Top Expert:
  • Riccar Master
  • 53,816 Answers
Adjust the setting on the vacuum head to pile or plush carpet
it is a simple lever that raises the hood to allow more air under it to make it easier to push
Posted on Oct 07, 2015
HOw do I replace the riccar 8850 hose?
Inside the bad compartment you can see the swivel portion sticking through. You will need to take a screwdriver and push in on the tabs on the swivel to release it so it can be removed from the body of the vacuum. The new hose ans swivel will just push into the hole and the tabs will hold it in.
May 04, 2014 | Riccar 8850 Vacuum
Belt continually slips off Riccar upright vacuum
Your 8850 is an old vacuum. If a new belt does not solve the problem it may need a new rubber motor mount or metal pivot. Both parts are inexpensive and available from your Riccar dealer. If it's been a while since it's been serviced it would be wise to have it serviced by your dealer. A Riccar vacuum will last for many years but should be serviced once a year like all vacuums.
Apr 07, 2014 | Riccar 8850 Vacuum
Can't adjust from floor setting to carpet setting
The carpet / floor selector moves a rod which adjusts the clutch, Your model is over 10 years old, it may need a new belt, clutch rubber pad or just need adjusted. If you don't know how to perform these services take your vacuum to your local Riccar dealer for service. It's the least expensive way to keep it working properly for many years.
Replacing a belt on the Riccar 8850...I see how the brush assembly will work with the new belt. But I don't see how a new belt will turn on the small rod extending from the motor. Is there a pully missing?
There is not a pulley missing, when the belt is tight the shaft will turn the belt but when the belt loses elasticity it will slip on the shaft when being used on the carpet. Replace the n
belt at least once or twice per year.
Apr 04, 2011 | Riccar 8850 Vacuum
No suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Dec 29, 2009 | Riccar 8850 Vacuum
Replacing belt but brush does not turn
Are you sure that you have the right size of belt? This is the correct belt:
Riccar 8850 Belt
Dec 16, 2009 | Riccar 8850 Vacuum
Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
Dec 15, 2009 | Riccar 8850 Vacuum
No suction
Replace your belt. Remove the baseplate, remove the brushroll, place a new belt around the motor pulley, then around the pulley on the brushroll, and pull the brushroll back into place in the nozzle. Spin it by hand to make sure it spins, (otherwise you'll break the belt again,) and then replace the baseplate. Party.
-R
Feb 25, 2009 | Riccar 8850 Vacuum
How to replace Riccar Roller Brush Bristles.
On the belt end, there is a clip #59 to remove then you can take the brush roll apart, replace the brush strips and put it back together.
Jan 02, 2009 | Riccar 8850 Vacuum
Vacuums Logo
199 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
