Question about Refrigerators
Side by side frig freezer --daewood frs--u20fas z268
Freezer icing right up ---frig not working ???????
Posted by bonney on
Andrew Taylor
    Top Expert:
  • Refrigerators Master
  • 33,311 Answers
The cold air for the fridge comes from a vent from the freezer. Fully defrost the freezer and the fridge will work. Lower the setting.
Posted on Oct 07, 2015
We have a FRS-U20FA
The water dispenser tube has a low wattage element to prevent the water from freezing in the tube. its normal. Check to see if the evaporator fan is running. Open the freezer door and when the fridge is running, press the switch on the side wall. The freezer light should go out and then you should hear the fan running at the back of the freezer compartment. Common symptoms of a failed fan is ice growing down the back of the freezer compartment , poor refrigeration in the food compartment and partial or poor freezing of food in the freezer. If the fridge is less than 2 years old, it will be under warranty. (Contact Castel Electronics in Melbourne 13
00733962) If its over, they can give you the name and number of a local agent. There are a lot of bits and pieces to remove to get to the fan on an ice and water model, also the rear panel inside the freezer should be removed to make sure ice hasn't blocked the air ducts. If you are not confident in doing it, get one of their agents to sort it out. Cost of fan motor, call and labour should be around $200 to $220
Dec 26, 2013 | Daewoo Refrigerators
Fan no go freezer compartment frs-u20fas z268
Check to see if you have voltage at the fan. If you do, you will need to replace the fan. Here is the part to order.
Nov 21, 2012 | Daewoo Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Freezer not defrosting
Most likely there is a leak in your freezer seal allowing moisture to build up and form the ice blockage.
Jun 17, 2009 | Jenn-Air JCD2389G Side by Side...
GSS220 side by side refrig does not defrost and no longer cold
the frig is cold by the air for the freezer so if it all ice insinde no air can pass to the frig 1 turn off you frig ,, yes it not fun but you will reset the frig ( more that 3 hour )
meanwile , take out the ice of you freezer ,lower you temperature in the freezer and restart
if it do that a other time , it easy it you temperature detecter it is broken .. some you need to change it
Jun 07, 2009 | GE Refrigerators
PLHS69EGSS1 Freezer not cooling properly but Frig is OK
This is one time you might need gas. Your freezer needs to be 20 degrees or less for the ice maker to work.
May 01, 2009 | Frigidaire PLHS69EGSS Stainless Steel Side...
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
