Question about HP ProLiant Computers & Internet
How do I fix window 10 to listen audio mp3 cd
Posted by Ayele kebret on
Cd player skips
CD disk bad. (audio disc bad or scratched)
or CD dont really support disk media format , is this a CDDA or MP3
some early MP3 disc drives do MP3 very poorly
or skips when you hit bumps in the road.
only that disc skips.?
Dec 23, 2013 | 2005 Toyota Sienna LE
Hi. I have a Samsung Sansa MP3 clip-on player. I listen to audio books all the time. I order an audio book online. It comes to me in either a regular CD or an MP3 version (however they manufacture it)....
Normally MP3 players can only play music/audio files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apr 18, 2011 | Samsung Computers & Internet
How do you download music to an mp3 player from a cd?
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
May 01, 2010 | Coby MP-C653 MP3 Player
What is MP3?
MP3 is the prefered method for music downloads.
MP3 is a file format on which music is created for CD downloads which can be played either, on a computer or an MP3 player (like the one on your cell phone.)
Your computer uses pre-installed software called a media player to play the MP3 songs on the CD download. If you have a Windows based PC for example (Windows XP, Vista etc.) when you click on the download - Windows Media Player will open and automatically start playing the songs.
So, you're safe to download the music in MP3 format. It will be of good sound quality.
Mar 29, 2010 | Microsoft Windows XP Professional for PC
How do I put a cd onto my phillips go gear player?
On a Windows System, most GoGear players can be detected in either
Windows Media Player 10 or 11. Use the WMP version that matches your player.
Before putting music onto the player, audio should already be or must be converted into the correct format.
Most GoGear mp3 players support music in the format mp3 and wma: this is the extension of a compressed audio file: e.g. track1.mp3 or song2.wma, similar to a text file, that could bare the name textfile1.txt .
Consult the manual of your model player for the correct extension and bitrate: bitrate is the density of the bits used to make a compressed audio file.
In WMP 10 or 11 the function RIP can be used to convert an 'ordinary' audio CD into mp3 audio tracks.
Look in the player's manual or go to the site of Microsoft for more information about using Windows Media Player.
When needing more help from this side, just add a comment in this thread.
Feb 07, 2010 | Philips GOGEAR SA6045 MP3 Player
My mp 3 player
You may have inadvertently enabled a Preview mode on your MP3 player. Many of the old CD players had this, so you could listen to the first 10-20 seconds of a song and then move on. I would try resetting the settings on your MP3 player to Factory Settings and seeing if this fixes the problem.
Jun 20, 2009 | Audio Players & Recorders
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Transfering albums onto MP3 player
You have to make sure that the ID3 tags have the album name on them. right click song, select properties, and edit the id3 tag. For more instructions, go to www.microsoft.com and search for "edit id3 tags in windows media player"
Jul 06, 2008 | Samsung YP-K3 MP3 Player
Unable to write audio cd's on samsung laptop
When you burn the music have you changed the format of the file to .cda because .mp3 will not work on an ordinary cd player. One way to burn audio is through Windows Media Player. That will covert the file format so you can listen to it. Just tell me if this dosn't help.
All The Best,
RCF
May 27, 2008 | Computers & Internet
Is there hope for the e250?
have you tried to use sansas media converter? it's on the cd when u buy it
Jan 16, 2008 | SanDisk Sansa e250 MP3 Player
Open Questions:
Computers & Internet Logo
631 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
