Question about Just Wireless Radio Communications
I have a just wireless bluetooth bt-40 will it work with my ps3
Posted by Christian Boswell on
3 Related Answers
Anonymous
SOURCE: ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Posted on Jan 21, 2008
Anonymous
  • 3 Answers
SOURCE: Need PIN for Just wireless bluetooth
If you haven't reset the password, try 0000 or 1234. That is usually the defalt for most devices.
Posted on Mar 24, 2009
jameskent011
John Burns
  • 33 Answers
SOURCE: MS9535 BT Bluetooth Wireless Barcode Scanner mac
The MS9535 BT Bluetooth Wireless Barcode Scanner will enable you to connect bar code data without being tied to your mobile or desktop computer. It is an ideal solution for a number of application which include the different point of solution, warehouses, it is having a serial magic which will allow the MS9535 to work at virtually any device.
Assurance Wireless
Posted on Mar 02, 2015
Hi , my friend gave me a madcatz bluetooth ear pierced for me to use for my ps3 ....i been clicking ..settings , then manage bluetooth devices , (every website says i should click "register bluetooth...
You need to put the device into pair mode, consult the instruction manual with how to do that (usually means hold the power button until you get a blue/red flash) when you have the device in pairing mode, when you search it will show up.
Rylan
Dec 13, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I bought a madcatz bluetooth headset for ps3 and it wont connect and let me scan. it was made in 2007. Any way I can fix it??
did it ever work for you are you holding the power-sync button long enough on the bt headset's load up light should stay solid or keep blinking till it sync's up start the ps3 bluetooth settings to start looking while you start to connect it hope that helps if not the bt set could be faulty try syncing it to a cell phone
Nov 17, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Im trying to set up my blue tooth to work on my ps3 but no signal is found what am i doing wrong?
You need to pair your PS3 with your bluetooth headset.
  1. Turn on your PS3's bluetooth and search for bluetooth devices.
  2. While the PS3 is searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the PS3 finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Oct 25, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
Mar 24, 2009 | Cell Phones
Ps3 bluetooth connection
I think you are mixing up two different technologies. You said you have recently bought a Wireless Router and when you try scanning for Bluetooth devices you can't find it?
First of all, Bluetooth isn't Wi-Fi. You should go to Network Settings under Settings in the XMB and choose for a Wireless Connection and then let it scan.
Be sure you don't have a 40 GB PlayStation 3 since they don't have Wi-Fi.
I hope this helps. Please rate.
Greetings,
DarkNeogen.
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
How do i hook my bluetooth to my ps3
After you have connected the headset to the PS3™ system, you can verify that the PS3™ system is receiving voice input from the headset
and that the headset is correctly playing output.
To test and configure your headset
In your PS3™ system’s home menu, go to [Settings] > [Accessory Settings] > [Audio Device Settings].
After you pair a Bluetooth® device with the PS3™ system, the Bluetooth® device becomes the default for both input and output audio. If the
headset is working correctly, you can hear your voice loopback in the headset. The audio input bar will indicate your voice level.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Radio Communications Logo
155 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
