Have a problem where the dishwasher will not fill with water , am a plumber so have checked the water supply , hose , removed the filter and pressure reduction . Start button flashes 6 times another thing , it doesnt have the sieve filters on the sump ( didnt come with them ) Cheers Mark
SOURCE: when dishwasher cycle is started
make sure water is on to dishwasher. second, check the float switch to make sure it is working properly. the float switch is located inside the dishwasher in the front. just lift up on the float and back down and make sure you can hear the switch clicking. try and run unit.
if that doesn't work, take of the bottom kick panel and remove the wires to the water valve. with an ohm meter on voltage, turn the dishwasher on and make sure there is proper voltage going to the water valve. if that is ok, either your water valve is plugged or bad. Joe
SOURCE: Dishwasher will not fill. Water lines have been checked and filters are clean
Flow detection shot?
Expensive one I had couple of months ago on a Bauknecht. 300 dollars. New machine at 250. Scrapped it.
Flow detector was coupled at automatic waterstop.
Beware if you have a old machine drying with hot air, most all new models use condensation leaving your dishes etc a bit bit wet :(
SOURCE: My Viking under the counter
there is a water valve usually located at the front left under the unit . this could be bad or water pressure could also be a problem , make sure you have a good sized hose suppling the water.
SOURCE: dishwasher will not fill, water supply checked OK,
Check the float switch. Sometimes you can jiggle it around to get it working. Also check the leads going to the water inlet to see if you have power unit must be started to check this. If you have power to the valve it has failed if not check that float switch for continuity. One of the leads from the water inlet goes to the float switch.
SOURCE: Our dishwasher starts but wont
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
