Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Where is the deflection board
I have the thumping sound and a flashing blue power light, after I replaced the stk-392-110 components, can you tell me what happened?
  • Anonymous Nov 28, 2007
    I have a similar model tv that I was working on that began thumping and replaced the stk 392-110's to no avail. in my case I know for sure that the soldering is fine (iv'e been doing it for years and checked all connections for shorts and opens before I put the board back) Might be a while before I can get back to it though since the TV is in Pittsburgh and I was just visiting for thanksgiving.
    Problem Solver:
  • 12 Answers
Some things I have found that you could try
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
[email protected]
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Posted on Dec 06, 2007
    Genius:
  • 1,694 Answers
Was there a change in symptom from original?? Then recheck
your soldering with meter....short circuit???? Let me know...T.
Posted on Nov 26, 2007
  • Vista Electronics Nov 26, 2007
    Ps. Check all fuse devices after you find short.................T.
Sound system makes a thump thump noise
Your speaker is now blown.. Replace the Speaker and you will get sound back instantly. Happened to my Drivers Speaker last week, replaced the speaker and life is good again.
Mar 01, 2014 | 2010 Kia Soul
The blue power light and the blue and red battery lights keep flashing and won't stop Why?
Sounds like the battery itself is going bad and needs to be replaced. The blinking lights are a code that you can find at the OEM website and it will tell you exactly what is going on..
Feb 01, 2014 | Acer C7 Chromebook
My Samsung LE32N7 does not come on. The blue light under the screen constantly flashes without the tv coming on.
Hi, maybe the TV controller board is blocked, you can reset it, by disconnecting power cable from outlet for about 5 minutes, if that doesn't work, possibly and internal board or component must be repaired of replaced, in such case it's better to contact an authorized Samsung service center or technician to check your TV.
Nov 07, 2017 | Televison & Video
Toshiba 57h84 sounds like it is turning on but the only thing it is doing is the red light on the power button flashes no sound on picture nothing
CK your hori output Transistor and small blue capacitor round it feed the hori output 2k high voltage cap if they are OK then Replace both of your STK ICs they will have part number on them. For Parts Call Mats 1-800-628-1118
Dec 08, 2009 | Toshiba 57H84 57" Rear Projection...
HI, my JVC AV-48wp30 has the same symptoms as other posts here. Powers on with no screen, HV, and no CRT heater coils light up. Thumping sound in speakers, and then shuts off. Blue light flashes. ...
take off the front panel and unplug the convergance board up front just behinf panel if the set now comes on replace your con amps if not you have a power supply issue more than likly the con amps are bad
Nov 20, 2009 | JVC AV-48WP30 48" Rear Projection...
I have a Pt-56hx41pf Panasonic and when I turn it on it trips off with a red light next to the led power button flashing. When I turn it on again it wont come on. If I unplug it the tv would come on to...
CK your hori output ,& blue capacitor 1200pf 2000v see if it is burt if these are OK Then Replace Both of your STKsThey are your convergence ICs but they also cao affect power.They are big black chips with STK on them IF they are 392-110s upgrade to 180s- if they are 020s use 040s if 560or 570 use that number for part to replace there is no upgrade and big differents in 560s-570s.If you need anymore help let me know. Resolder all poor connections you find.
Dec 23, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Won't power up and power button light flashes
when you replaced the convergence amps did you check and replace the resistors? it seems like they always take out two or more resistors. the problem is on the convergence board, i have the same tv that did the same thing. if the speakers are still thumping, you may have got a dud amp. i recommend using the factory stk392-110 amps. make sure all of your solder connections are good and none of them are touching. also, when you get the set back on you will need to manually adjust the convergence from the menu. you will need the factory remote. if you find bad resistors, the values are on them, but if you need the values and wattage, then use this page:
http://home.comcast.net/~dande76530/ConvergenceOutSchematiics.pdf
hope this helps you.
Apr 06, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP30 will not give a picture
Replace the convergence IC`s again using original Sanyo chips (STK 392-110 or STK 392-180). Make sure to use plenty of heat sink compound. Coat the entire back side of the chips. Also look to see if any of the low ohm resistors are burned. A shorted chip will cause the thumping sound and the set will shutdown. I am guessing that you used generic IC`s as a replacement. They are cheap and the leggs fall off when you apply too much heat during soldering. Dont wory about the CRT driver or the deflection board, they are probably fine.
Dec 12, 2007 | JVC AV-48WP30 48" Rear Projection...
No responce except thumping noise
PLEASE TRY TO CHANGE AGAIN THE CONVERGANCE IC'S
Oct 02, 2007 | JVC AV-48WP30 48" Rear Projection...
No Picture / No Sound
What was happening before can put you close to what when out. If you had color problems or sound, or even picture going small. these are symptoms that causes the set to go out. If color look in the convergence area and look for blown fuses and bad resistors. If just went out the look at horizontal output transistor.
Aug 24, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
247 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
