Question about Panasonic Viera TH-50PZ80U Plasma TV
How to hang a flatscreen TV on a wall - Panasonic Viera TH-50PZ80U Plasma TV
Posted by Ori Inbar on
Electro Med Services
  • Panasonic Master
  • 6,694 Answers
Posted on Oct 06, 2015
How do i give my tv an hdmi channel? Do i have to buy a hdmi cable? and if I do which cable? I want to use an xbox one but It won't show due to me not having an Hdmi channel so I was wondering howican
HDMI is a data protocol and includes the associated ports and cables it is not a channel. If Your TV Does not have an HDMI port you can use a converter to change it To a connection your TV Does support. Be aware a cable with the appropriate ends is not the same as a converter...a converter changes the language to something the tv can understand.
Jul 30, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
This is a 32" flat screen TV that doesn't work. This has been going on for a while. Changed batteries in remote, nothing, put in different wall socket,
Bringing a flat-screen TV back from the dead - CNET
www.cnet.com > Tech Culture
CNETJan 19, 2011 - There are few technology tragedies as sad as a dead big-screen TV. ...good reason to upgrade to a new flat-screen doesn't come along every day, and I ...and eventually got the set working by replacing first, a blown fuse and ...
Flatscreen TVs - ConsumerAffairs.com
www.consumeraffairs.com/flatscreen-tvs
A TV repairman says today's flat-screen TVs are poorly designed ... "The TV wasworking fine up until Saturday, when it suddenly developed vertical .... is you can have it fixed for free under the warranty (if it doesn't run out - buy extended).
Top 5 Best Cheap Flat Screen TVs ' Heavy.com
heavy.com/tech/2014/10/top-best-cheap-flat-screen-tv-4k-deals-hdtv/
Oct 27, 2014 - Read on to see which cheap flat screen TV sets made our list. ... or secondary TV, but it also works great as a monitor or as a screen for console gaming..... an elderly family member who doesn't want or need those features
Dec 19, 2015 | Televison & Video
Code for universal remote for amstar flatscreen tv code dynexrs232
A star 26855 FHD superglue TV
Can you get a wall mount for this unit?
May 31, 2012 | Televison & Video
I have 1 tv Thomson 32E92NH22 LCD and i lost the manual.I'm trying to get it hanged on the wall.No ideea what tipe of screw i need to conect the tv to the wall hanger.Can somebody halpe me?Thanx a...
Hi mona_77a,
You can find the manual for your TV here.
Your Thomson TV is compatible with a VESA FDMI (Flat Display Mounting Interface.)
These typically use "VESA screws."
VESA screws tend to be metric sizes of M4 (0.7mm pitch). The length is typically 10mm, but would depend on the bracket (if you don't have a gauge handy, just put a small stick of some sort in there and mark it off with a felt pen, then measure).
Washers are a really good idea, especially if you decide on thumbscrews with plastic heads.
You may be interested in eHow's tutorial on how to mount a flatscreen TV to a wall. This is for a 42 inch screen, but the same rules should apply with a 32 inch.
  • Open Link in New Tab
  • Download
Mar 01, 2011 | Televison & Video
How can use to LG LCD tv in wall hang
First you get the wall hanger. Screw one part to the wall. And then screw the other part to the TV. then you hang the TV on the part screwed to the wall.
Hope this solution has been helpful?
Sep 26, 2010 | LG 42LC2D 42 in. LCD HDTV
42 Inch Samsung Flatscreen; 1.5 years old. Won't
First test the wall outlet, try plugging a lamp into the same outlet see if it works. If the outlet works then read the following below. If the wall outlet doesn't work then plug the TV into another outlet.
If its not the wall outlet:
Unfortunately the power supply has a problem sustaining DC output. This can be caused from several fault scenarios. Get someone who is technically savvy and I will show them via e-mail what to test to fix this problem for you. Or you can take it to your local repair center.
Dec 20, 2009 | Samsung HP-T4254 42 in. Plasma Television
I'm trying to hang my flatscreen tv above fireplace and need help
Wendy,
When attaching your wall mount to the brick you should use a metal lag shield designed for masonry. These can be found at the local hardware store but i would carry the mounting bracket with you so that you can ensure that you get the appropriate size of fastener that will pass through the bracket. As far as the heat goes, it really depends on the amount of heat the system will be subject to. Some fireplaces are more for decoration and produce very little heat above the mantle area. Others that have blowers on them or are left with the doors open genrate considerable heat.
I would not advise the mounting of the tv above the fireplace in my professional opinion. The cooler you can keep electronics - to a point- will greatly increase the service life of the appliance.I hope this is of assistance to you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
Nov 13, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Ilo 27" flatscreen
I moved and the manual and remote got lost. I bought a ONE FOR ALL remote that has the iLO printed on the add but I can't get the tv to work, I tried all the codes but nothing worked. How can I get a manual from the computer to work this iLO tv, which I am unable to use. Maybe I should have purchased a Sony.
Sep 30, 2007 | iLO Televison & Video
Panasonic Viera TH-50PZ80U Plasma TV Logo
145 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
