Question about Russell Hobbs Blenders
My blender leaks while I am making smoothie
I have the colour blender, only had it for about a month, how can I fix it
Posted by Lillian on
Deborah Davis
    New Friend:
Check to be sure your rubber gasket is clean and in the proper place which should be between the jug and the blade asembly. Also I have seen leaking when the assembly was tightened too much.
If you still have your receipt etc you may be able to exchange the unit where you purchased it. Alternatively contact the manufacturer and see if they can replace under warrenty
Posted on Oct 06, 2015
Smoothie maker 600
Check to see if the jar has any cracks or if the blade assembly or collar have any cracks.
Is it possibly leaking from the tap valve?
If the blades or tap lever are cracked I would recommend replacing them, however if the jar is cracked i would just buy a new blender. These are great for smoothies but they are all discontinued and parts wont be available for much longer.
May 05, 2013 | Back to Basics 600 Smoothie Plus Work Top...
V5785 mixing part broken (leaking)
I need the villaware smoothie maker top model V5785 as mine broke & can't find anywhere. Please help!
Apr 19, 2010 | VillaWare 4785 Smoothee Work Top Blender
Need white base that blade sits on.
I'm going to super glue the crack that is causing mine to leak.
Jul 28, 2009 | Back to Basics Smoothie Elite Work Top...
Leaking Blender
yes you have a defective rubber seal on the pitcher base
Apr 16, 2009 | Back to Basics Blender Solution 5500...
Blenders Logo
224 people viewed this question
Top Russell Hobbs Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
