I used to feed my receiver using the Digital Optical output of my TV. Now, the only way I can produce sound is via the Radio AND Pure Direct button. Thoughts on repair or where I could send it ?
Verify that the optical cable (or the tv optical output) is not the problem. try using a different audio source with optical output such as a cd player if you have.
Tried DVD Player also. However, it seems that if it were an input problem, then the radio would work fine without having to press Pure Direct.
It could be the dsp fried or just bad settings.
My denon required a factory reset and started working, but my hk had to replace the dsp board...try the reset first.
I'm having the same problem. Have tried resetting and using different cables. Any luck with your troubleshooting?
Model is RX-V673
