L
Lynn Hammond Posted on Oct 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is "PROTECTION" displayed, followed by shut off?
No visual signs of overheating etc.
Level 3:
Top Expert:
  • Audio Player... Master 76,851 Answers
  • Posted on Oct 05, 2015
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987209
Points
237762
Short circuited component/s at its audio output circuit, or short circuited speaker/s. Disconnect all the speakers from the set, and switch it ON; to see whether it displays protection now. If not, make sure that one or more speakers are the cause this problem. Try to find it. If there is protection displays; even after all the speakers are disconnected, the internal circuit has the fault. Need repair. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to get gathered related posts.
Mister Danger
Level 3:
  • Audio Player... Master 5,631 Answers
Mister Danger
Level 3:
Answers
5631
Questions
0
Helped
1197723
Points
47629
Even if it's not overheating, might have some circuit problem. suggest you to take you device to an electronic service or call a servicement, to check ciruits of your device
Even if it's a false alert, it's annoying because shuts off your system, so reason must be detected and repairde.
My sony Bravia Model KDL 46ex523 shut down today , it has the little red light blinking 2 times , any idea what it means ?
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Make a visual check of all PCBs looking for burnt/overheated parts.This will help identify the problem circuit.
Read more: http://www.agoraquest.com/viewtopic.php?topic=31721&forum=70#ixzz31Blk7TRX
3answers
Acer aspire overheating & rstarting.
you can replace the fan if you know how to do so but take it to a qualified technician and they will be able to sort it out for you and it should be that expensive
1helpful
My laptop turned off but it has 35% remaining battery
Laptop turns off suddenly? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
4helpful
3answers
Overheating and turning off
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Turns off suddenly
The computer will just randomly do a windows shutdown and then restart. Cleaned, changed the power supply and still does it.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the computer back on and figures out a way to foil the protection, the unit is probably doomed. Once a unit shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated unit is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Check the CPU fan if it is spinning and also the CPU itself put thermal paste. So that the heat from CPU will absorbed by the heat sink.
3helpful
2answers
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
1helpful
2answers
My laptop keeps shutting down at random times. I
Good luck
1helpful
2answers
My Toshiba m205 4806 shuts down spontaneously. The lap top feels warm but the fan is running. any suggestions?
The cpu get overheated and will shtdown to protect it. The fan continues to run until a CPU safe temperature is reached / sustained.
1. Use laptop on flat surface, not on pillow, carpet, bed, etc. that will restrict air flow. Using a can of compressed air, clear the air vents.
2. If the symptom continues, then the heat conductive paste between the cpu chip and the heatsink is no longer effective (hardened, too thin, etc.). Remove the heatsink and add thermal paste
($6 Radio Shack).
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Good luck !!!
Regards
PCmania
 Grubhead
Grubhead
SmartAviator
SmartAviator
