My pressure pump starts every 10 minutes, or so. The pressure drops and I hear what I believe is water continusly running (though the pumping stops when the WX-203 is pumping). I cannot find water coming from anything in or outside the house. It seems like our pressure is down a bit.
SOURCE: adjusting pressure tank set at 48 lbs and pressure
Pressure tank should be charged to 2 pounds less than your lowest pressure (ie28psi). Must be set with system under no (0) pressure.
SOURCE: when setting my tank pressure at 28 Lbs my pump will dhit down to
If your numbers are correct then your pressure switch is bad
SOURCE: Lots of water on basement floor at pressure tank.
sounds like the bladder tank at the well is ruptured this will cause pressure surge, and pump short cycling, and needs to be replaced asap.
