Question about Food Mixers
My Kitchen Aid Mixer from the US with a 110V motor was mistakenly plugged in a 220V. There was a loud pop and a bit of smoke.Can this still be repaired and/or replaced with 220V motor?
Posted by DADDF on
ray gallant
    Top Expert:
  • Food Mixers Master
  • 68,542 Answers
OOPS only kitchen aide can tell you this .
Posted on Oct 04, 2015
Why is my kitchen aid mixers so Loud?
Could be,among other things:
Very worn brushes (although, in this case, the mixer usually stops entirely).
Worn gear(s).
Grease congealed and not lubricating correctly.
In any case, see the Service Manual at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 16, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
110V 6ohz - 220V 50hz
Kitchenaid mixers are not recommended on the use of a converter as they are not tested under such conditions. Understanding this, using a convertor on your mixer may automatically void the 1 year warranty regardless of age.
There are international Kitchenaid dealers available if you are requiring 110V. You may contacted Kitchenaid Customer Service for more information.
Their toll-free telephone number is 1-800-541-6390.
Jun 23, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My kitchen aid mixer makes a clicking sound when it is on and will not mix properly. It spins, but sounds bad.
Check the motor brushes. You'll see two black plugs with flathead screwdrivera small one, Unscrew to check, if only springs or very worn,youll,know.Its a maintenance problem.
Mar 11, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid mixer, voltage issue
i want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Nov 10, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid 110v 450watt, I want to convert to 220v
Hi guys,
The only available Kitchen Aid stand mixers on the European markets are the Kitchen Aid Classic and the Kitchen Aid Artisan.
The best way is to contact a Kitchen Aid service center / repair facility in your area.
Here is the European website of Kitchen Aid: http://www.kitchenaid.eu/eu_EU/ka/ka_europe.htm
If you bought a different Kitchen Aid Stand Mixer (like the Professional series) you probably won't find the required parts to convert it to a European model. The only way would be to use a voltage converter.
I hope this helps.
Sep 24, 2008 | Food Mixers
Kitchenaid mixer professional motor
DO NOT DO IT. The Hz will destroy the morotr. The transofrmer only converts the voltage. You are better off buying a 220V version.
Apr 07, 2008 | KitchenAid Food Mixers
Food Mixers Logo
359 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
john h
Lawrence Oravetz
Are you a Food Mixer Expert? Answer questions, earn points and help others
