SOURCE: Canon Imageclass D780
Clean the platen glass and make sure the isn't any debris or ink on it, especially by the roller. If you make a copy thru the ADF while the ink is still wet it will deposit on the glass.
SOURCE: Mp510 Canon - printing and
Greetings,
Well you already finished with head alignments.
And it's not straight even on Copy ? It needs service, the print head is busted and you can't buy a new head & replace it.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
SOURCE: fax not printing correctly
Sounds like your print head is dirty if you are using a inkjet machine. Although you didn't say what machine. Your machine should perform a print head cleaning procedure if you turn the machine off and then on again. Otherwise you'll need to replace the print head which may or may not be part of the ink cartridge depending upon the machine in question - good luck
SOURCE: Lines in copy print
Its not a printer Issue, but its application issue. you will need to uninstall the printer first. then get the drivers those are compatible with the operating system that you use and install those new drivers.
reboot the computer and thats all.
Problem fixed.
SOURCE: printer prints every second line
Hello sir; I believe it's time to clean print head and ink cell, power on the machine open the cover ( as you replace cartridge) , when carriage move to the center , then UNPLUG the power cord. then you may move carriage freely by hand all the way to left, noe you can clean up ink cell easily.
Testimonial: "Printer is now working fine. However I had to clean the nozzles a few more times . Thank You for your help."
