Question about Vizio E500i-B1 50-Inch 1080p Smart LED HDTV
No back-light,No picture, but has sounds. How can I fix it?
1. Most of time, it doesn't has picture after power on it, but sometimes, for example, unplug power for more than 2-3 hours, it has picture when plugin power again. 2. Sometimes, picture is gone suddenly, but has sounds.
Posted by Guang on
Bobby Lynn
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
On this TV there are 3 boards, 1) power supply board, 2) Video and input board and 3) t con board. The power supply board powers the video and input board. The video and input board powers the T con board. With the tv in black screen mode check the voltages as outlined on the diagram next to the two white connectors on the brown board that feed the video and input board. If all the voltages are correct when the screen is black, then the problem is either the video input board or the t con. If you see the Vizio logo at start up, my guess is that the video and input board is bad. Power board is brown, video and input board is green and t con is under the metal plate at the bottom of the screen.
Posted on May 29, 2016
    Top Expert:
  • Vizio Master
  • 76,396 Answers
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Oct 04, 2015
Testimonial: "thanks for your help. I intended to replace the power board, but I'm not sure if it's bad. Actually, I checked it, everything looks good except one pin, it is broken. but my concern is why it works sometimes."
1 Related Answer
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: 17 month old set; Picture gone. Direst TV repairman says it's the backlight bulb. Others say it's a Board.
it might be inverter board it is not backlight bulb according to my expertise bcoz once it goes off it dont come back
but u see inverter and CCFL backlight bulb failing symptoms are so same that u cant simply distinguish but i am sure u have one of these two problems inverter is more chance
Kindly rate me well
Regards
Zohail
Posted on May 23, 2009
Mysony wega KDP-57WS655 press power button straight to standby flashing 10 times
Indicates a problem with the high voltage circuit. You could try unplugging the power cord, plug it back in and try again. If that doesn't work unplug the power cord again but leave unplugged for at least five hours and try again. Still doesn't work find a local repair shop that works on sony tvs and have them fix it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board that needs to repair.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 22, 2012 | Samsung SyncMaster 940N Flat panel Monitor
Our power went out, and our tv wont turn back on, is there a reset switch?
sometimes you can reset the mainboard by unplugging the set for 30minutes to 1 hour and see if it resets. If that doesn't work, you can try holdin down the channel down and volume down button on the tv itself at the same time you plug in the unit and see if that helps
Sep 25, 2011 | Vizio L32 32 in. LCD HDTV
Our tv doesn't have a picture but it has sound.
Normal problem. Cable connections are loose. Do this Unplug all the cables including the power on Wait for sometime - minute or more. Re connect all the cables. See that they are secured in the sockets properly. Switch on the power. Your picture problem should be over.
Sep 24, 2011 | Televison & Video
I have a philips 50'' television, model #50pf9631d/37 with a flashing red light on power light, sometimes i unplugged the unit about 5 or 6 times for about an hour, then try to turn it on quickly with the...
Two problems: first, tv turns off for about 10 seconds after being on awhile, then turns back on. 2nd, picture will sometimes go black horizontally displaying only half of the upper screen. This will go on for about an hour off and on.
Dec 31, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have no picture or sound when i hit the power button it clicks off
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 18, 2009 | Mitsubishi WS-55807 TV
Mitsubishi ws-55809 goes to white foggy screen occasionally
It will cost between 30.00 - 70.00 dollars to do it yourself depending on if you buy the parts seperate or as kit.
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
ASTAR LTV-3201 will not show picture anymore
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Dec 27, 2008 | Astar LTV-3201 32 in. LCD Television
Tv powers off after 15 mins to 2 hours
what is the model # and brand
May 02, 2008 | Televison & Video
Open Questions:
Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
220 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
