Such data are available only to their factories and offices for quality. We do not have information on fires in their dishwashers.
I think it is more important to determine where it comes from smell of fire so as not to endanger your property and lives.
So, I suggest that you stop using the dishwasher until you clear the reasons of bad smell of fire.
When this type of problem happens, you most likely need to take apart your heater and clean it well. If it still doesn't work after that, blow it out with an air compressor. If then it still isn't working, I suggest you sell that heater and buy a new one.
Check the fan on broken blades - even a small part missing can cause unusual sounds. If parts are new / serviced - smell can be due to labels getting hot and emitting slight burning smell. Classic are exhaust pipes with partnumber labels left on there. If he smell stays, something in the interior might come from a crash car which was partly burned.
If it smells like plastic burning. Stop using it immediately. As there could be an electrical short or overheating of the unit. If doesn't smell like plastic burning, you'll need to be more descriptive of what the odor smells like.
UN -PLUG IT,,,,, THAT "FUNNY SMELL" SOUNDS LIKE IT IS SHORTING OUT
PERHAPS THE MEGATRON HAS GONE BAD, THE MEGATRON IS THE
HEART OF ANY MICROWAVE
AS A EX- FIREMAN, I KNOW FROM FIRST HAND EXPERIENCE THAT
"A FUNNY SMELL " OR " UN-USUALL SMELL COMING FROM AN ELECTRICAL
ITEM IS A SIGN OF DANGER
your car may not be burning off all the fuel or you are leaking. just because you dont see it on the floor doesnt mean that your not leaking. because its hot under there your evaporating faster than you drip. check your lines starting at tank. check under hood where it connects to injection system. run the engine and smell exhaust for fuel. put your hand at the tip while engine is cold running. if you get fuel go get a tune up. if smell it while driving you have a leak. i would need more info on the car. like has it been running a little less normal?
Even though the brush is spinning, you probably need to replace the belt
because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
