In this problem change the cassette player belt it will be OK 100% .I just solve the problem in my set
Sony music system MHC-GZR77D eject
message disply & set is stand by mode how to solve problems
U have casste player upper side then change the belt and chek out the relatedd problm like motar etc
Where I can get that belt set answer me quick
I have replaced the mechanical rubber tape. But eject stanby still appears. it's the solution
Https://www.youtube.com/watch?v=uxnpdkR-MdI
Moody, it sounds like you have a short in the circuit. Check all of your wires, especially speaker wires and make sure there are no bare wires exposed. If there are none, and the protective device trips everytime you unplug it and plug it back in, I'm afraid it's time for a new unit.
I am having a problem with the audio set that I own and I can not review a Mraczkm My problem is that when I raise the voice and getting his degree and issue the vibration of the Group automatic closure and can not start again until separated from the socket I hope you reply as soon as possible, thank you for your help.
I hope you help me and continue with me on This e-mail.
[email protected]
[email protected]
Chek the back fan and related supply
Only cassette player belt? Or also cd player belt
Sir, my mhc totally off only display showing but after few seconds it turns off!
How to deactivate dolby digital system in mini hifi mhc-gzr5d
Hi soubhik ..... same problem with my system. Pls help if u could resolve
[email protected]
SOURCE: Sony MHC-2800 setting the clock
Hi, it's simple. First press "Timer1" and Timer2" buttons together, clock on display will start blinking, by cursors "Up/Down" you can change the value of hours and minutes (switching between hours/minutes by "Left/Right" cursor). To save set time press "Memory". Enjoy your set clock :)
SOURCE: dvd not playing.c 31 00 occur
The only thing you can do is get a CD DVD player cleaner with liquid. Found at any store these days, then run it a couple times. If it plays, Problem solved, if not, it must be repaired. They will put a new transport in the unit. Usually runs 100-150 to replace. Weigh the cost to fix vs. the cost to replace and the age of the unit before you get it repaired. Hope this helps
SOURCE: sony mhc-dx5 power protect
something inside the unit has become faulty electronically, otherwise if u have moved the unit with cds inside, they may be out of allignment and causing the unit to go into protect.
SOURCE: owners manual for a Sony Mini Hi-Fi, component system,MHC-GX250
You can download the required manual from:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX250
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
SOURCE: sony 3 disc changer mhc-gx880 has broken belt. How
You have to open the unit with screws in the back and push it out by hand, there should be a series of gears that you have to spin for the tray to come out. You may be able to gently push it by hand to come out.
what is the way
Same here. I don't know how to fix my Sony Music system. keeps on ejecting disply and set on standby .
I have sony mhc gn 1000 d and whenever I switch on power it says please wait and then goes into standby mode. So now I have removed the complete CD section , tuner and tape deck section. Now only power amp, main board, power board, switching board, surround board, function board and panel board is connected. Still there is same problem while there is nothing to eject now. So now I go to pin number 26 at IC 401 and removes the connect. But still the problem is there. So let me know how to repair it. I want to use my Sony mhc gn 1000 d as an audio amplifier by connecting it to audio output from a USB player.
para los que les arrojan el mensaje eject yo tengo un sony igual y resolv? el problema cambiando las ligas de las casetera ya que los equipos sony la mayor?a cuando los enciendes empiezan a chequear el sistema de discos y caseteras y si una de las ligas de las esta deslizando el equipo rechaza el chequeo pone en pausa el sistema espero que les sirva
Hi Hemant / Nimesh , sorry but were you able to set it right ? What was the issue. Similar issue I am facing. Please help and email me
[email protected]
