Try spray silicon lubricant through the top of the paper shredder and also from underneath the machine.
most shredders have special paper that has lubricant in the paper and you have to buy it and run it through the machine after xxxx amount of paper shredding, i just use spray
BUT NEVER USE WD40 IT WILL GUM UP THE MACHINE
SOURCE: My shredder stop shredding. has paper caught in itposted
You must have a stripped gear. Should be a number in op manual. Take the top cover off and look for the broken gear. Call them an order gear.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
SOURCE: Shredder will not sut down when finished
Dlcrrawford, You have a sensors problem replaced both.
good luck
Kacretail: You have a bad sensor. your sensors are going bland
replaced both.
good luck
Mhs65 your eye sensor is bad. cleaning will not always help
better to replaced,
Azamoral0729: you may have two problems: Your system board or your paper sensors. I will first replace the paper sensor.
the sensor is giving false reading to the main board This is why your machine keeps coming on or will not stop when you shred.
good luck
to U all
SOURCE: Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
SOURCE: Shredder won't shred any more.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
