Question about Breadman TR2200C Ultimate Bread Maker
WHAT DOES THE --L ERROR MEAN? I PUSH START AND ITS GIVING ME THAT ERROR (--L)
Posted by Mlv Jing Molano on
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
tip
Error 5B00
Error E27 means ink absorber full at this model Canon mp 160,170,180,190.
You reset the ink absorber like that:
1.printer is offline
2.push resume button is red and in the same time push power button
3.do no let resume (red) button,and push the resume button 2 times
4.wait to appears numer zero to the screen
5.them push four times to resume button
6.close the printer and start up
1helpful
Why is my Maytag Epicz model #MGDZ600TW2 not starting amd giving me an error code F01. What does it mean?
F01 is a control unit failure does this come up when you push the start button or did you go into diagnostic to get this code I have seen it come up as a false code check the start button does it spring back like all the other buttons if so replace control if not the button is broke
2answers
My xbox360 has one red light flashing
1 red light usualy means hardware failure. There is another error code you can get of of xbox. While machine is on push the the sync button on console and while sync is pushed in press eject button. The lights on the console will give you youre first digit. Theres 4 in total. Repeat pressing the sync and eject button till you have got the four digits and console is back to the red light.
When getting codes the lights will light up. 1 red light means 1 2 means 2 and so on. 4 red lights means 0. Let us know and ill get back to you.
2helpful
2answers
My sportsart 6150 treadmill gives an error code 1 when the speed button is pushed. motor moves slightly but then gives error code 1. thanks.
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
6helpful
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
MY WASHING MACHINE THEY DONT START WHEN I PUSH START IT SHOW UP THE WORDS ERR AND LOC
Error 11
Error 11 and or Error 17 is mean that CD is dirty or scratch, and the optic can not detect CD track.
Solved problem:
1. Clean the CD
2. Change open source by push knob going to "CD" display or push "search" from remote to "CD" display
3. If still come out Error 11, change the MP3 CD by Original CD with clean track CD.
4. For the last step, clean the optic sensor by CD cleaner for a few minute.
5. Check and try to play the CD again.
3helpful
3answers
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
5helpful
2answers
H2 Error
You have a thermistor open. That means that the device that reads the temperature in the fusing unit, has broken. You will need to replace the fusing unit to fix this problem. You could try a Sim 14 reset. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
Breadman TR2200C Ultimate Bread Maker Logo
Top Breadman Kitchen Appliances - Others Experts
Fahr Quad
mark woodring
mark woodring
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
