How do I remove the left cover on a phaff 2140. the piece that covers the tension discs.
Phaff 2140. removing the left cover of the machine. I have thread caught in the tension discs and I can't get at it. a bit nervous to just yank the cover off which i think is what I do. I can't see anything to unscrew. Help!
Re: How do I remove the left cover on a phaff 2140. the...
Don't know this machine but would avoid pulling anything off as screws have a habit of pinging out and never going back. Try pulling a thicker piece of thread or fabric through the tension disks to dislodge whatever is there first
"Floss" the tension disks - this is nothing more than running a heavy thread (12 weight or upholstery) through the thread path, grasping the thread at the spool and the end that is through the needle and "flossing" just like you would your teeth - slide the thread back and forth through the disks/thread path. This will often-times pull through whatever is stuck!
If the thread is more deeply tangled than "flossing" will fix, you CAN remove the top of the machine to better see it. I would, however, recommend you take the machine to a Pfaff-trained tech if this is the case - things that can be damaged if you're not trained on the machine. However, if you're wanting to give it a try (the thread may be easily visible and easy to get to):
Remove the stitch lid - there are little metal clips at the base of the lid that you can push outwards to remove the lid - can't get the top off without removing lid.
In the well of the machine top are a few screws (2 if I'm remembering correctly). The screws are star-shaped as opposed to Phillips or Flat - special screwdriver is required. Just make sure you don't remove the screw that's holding the bobbin-winding mechanism on.
Once the screws are loosened, you'll have to maneuver the top out of it's position - this requires a little wiggling but is not impossible (just impossible to describe how to wiggle it!!)
Turn machine OFF and UNPLUG it. Too many electrical connection points you will be working around to take a chance!
VERY CAREFULLY... turn the handwheel towards you (never turn backwards) until you are able to view the entire race/thread path. If you can EASILY remove the stuck thread, go ahead and do it. If you have to do too much pulling and tugging, be VERY careful - if the thread is wrapped around the check spring, you may bend/break it.
Call the place you had the machine serviced and tell them they did not get it fixed; you need to have them to look at it again - as you wait and at no additional charge unless a part has to be replaced.
That is thread nesting or bird nesting. Could be the result of several things, but main reasons are upper tension too loose and the thread not being completely seated in the tension disk.
I would suggest taking the machine back to the one you bought it from & see if they have another one that will calibrate ,,& if they don't have one ,, I suggest another sewing machine dealer.. or you can try contacting Phaff customer support by phone or email & see what they say
On the back of the machine near where the foot pedal plus in should be a metal tag with the numbers on it. As for a manual, try this.. www.2instructions.com
