Question about GE Washing Machines
My GE close washer WWA8320B is slow filling cold water. Just got new well and grit got in the water feeding to the house water pipes.
My GE clothes washer WWA8320B is slow filling cold water. Just got new well and hot water was slow filling also. Checked hoses and removed grit from hose connections to water supply also checked hose connections at washer unit end. Water supply has good pressure and hot water into washer is ok, but cold is very slow still.
Posted by Michael Shu on
PaulC
    New Friend:
  • 32 Answers
There is a filter screen at the washer inlets for hot and cold water. Clean the screens
Posted on Oct 01, 2015
Why is my GE top load mechanical washer not filling with water?
You may need to use a Y adapter to feed pressure to both inlets to get the machine to fill. If it senses no pressure on one inlet it wont fill. You can run both inlets to on source. Since you did not post the model number it is hard to say. Some machines also test the water temp to see if it is warm enough to start or it needs to preheat.
Mar 05, 2018 | Washing Machines
Toto neorest leaking & low pressure wand
Sounds like the washer in the shutoff at the wall has failed and is partially blocking the fill pipe. Some rubber from it may have gotten into the toilet valve internally. With the wall valve closed, try to remove the connection pipe to the toilet. If you can do it without water continuing to flow out of the wall shut off...then remove the pipe from the wall shut off. Flush the toilet. Now, apply air pressure to the rubber hose the goes into the overflow pipe. That may clear the valve in the tank and solve both problems. If you cannot stop the water at the wall shut off, close the water valve feeding the house. Remove static water pressure by opening the cold water a the kitchen sink faucet. Now you can open the wall shutoff valve and replace the washer and clean it out....
Mar 08, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Front load washer filling up with water when off
if it's off or unpluged and still filling up you have a bad water valve,mark the hoses if they're not marked already so you know where the hot and cold fill hoses go after you change out the water valve on the washer,usually sediment gets stuck in the valve stopping it from closing and the water will keep filling into the washer,i've seen houses flooded from this,shut down the house valve that feeds the washer until you get the new washer valve.hope this helps and good luck,next time send the brand name and model number.
Oct 06, 2011 | Washing Machines
I am getting a EFO then E10 error message after I start a load of clothes...which means I have to cancel the load.
E10/EFO error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Feb 07, 2011 | Frigidaire Affinity ATF7000ES Front Load...
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
Nov 10, 2017 | GE WPGT9360EPL Top Load Washer
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Jun 28, 2009 | Admiral AW22 Top Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
163 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
