The ice bucket is stuck. I have removed it before easily but now it is stuck. Any tips on removing it?
SOURCE: I cannot remove the ice
Hi ndb2157,
Please determine whether the ice bucket is being blocked by the ice or by the part of the icemaker is being dislodged. If it's ice blocking it, please reinsert the bucket, closing the doors, then dispense some ice to see if the auger in the bucket can move the ice out of the way so the bucket can be removed.
Hope it helps.
Thank you for using FixYa.
SOURCE: not making ice
the number problem w/your model is the ice-mkr's module(motor). part 8201515.if your i/m's ejector fingers are not resting at around the 2 o'clock position,then more then likely you have a broken module. the red blinking light normal and it only turns off during the harvest cycle.
SOURCE: PFSS6PKW remove ice maker
Try the instruction's in this You-Tube Clip below. Thanks Sea Breeze
Ice-Maker-Assembly-WR30X10097-00657897
