For e207 model, error code should be in C44, F14, and etc...
Assume your error is C43, check the fuser thermistor, clear the error using 08-400 = Any value => "0"
perform the following:
1. Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "3" or "4" to "0",
then press [OK] (to cancel [C413 / C414]).
4. Turn the power OFF and then back ON. Make sure that the
equipment enters the normal ready state.
In the interim you may try the following one time to see if it is a false error... Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Contact your Toshiba technician (there should be an 800 number label on the unit for service. Do Not keep resetting, may cause damage to Fuser Unit.
Step 1:- Switch off the machine
Step 2:- Press 0 & 8 and switch on the machine.
Step 3:- Now the machine comes to service mode.
Step 4:- Now press 2002 and then start button
Step 5:- See the current error value and change to 0.
Step 6:- Press ok .
Step 7:- Switch off and on to check if problem is solved .
Step 8:- if still you get c413 errror,you may have to remove the fuser unit and physically check for heater lamp broken, or thermistor abnormality, and corresponding connectors.
Thermistor abnormality during warming up or in ready status.
simultaneously.
Step 6:- Press ok .
simultaneously.
Perform the following:
simultaneously.
Thermistor/heater lamp abnormality at power-
ON: Thermistor abnormality is detected at
power-ON or the fuser roller temperature does
not rise within a specified period of time after
power-ON.
