Washing Machines Logo
Iris David Posted on Oct 01, 2015
Model W797. Why won't tub spin or water empty?
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Apr 20, 2008
SOURCE: Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
What could be wrong if my ge model wbsrr3140d5ww wont spin ?
Does the pump empty the tub if so your low water sensor is bad if it
does not empty the tub then your pump is plugged up or bad.
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
1helpful
I can hear water in washing machine when I spin the empty tub
The balance ring has liquid in it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
GE top load profile washer won't spin. It starts
The tub hangs on 4 support rods. Lateral movement is kept in check with 4 bungy cords bolted to the top of the tub. If that washer is not level the tub will hang to one side and the fancy controls will declare an error. Make sure all your rods are good (they drag the base of the machine when worn out and make a heck of a racket) and the bungys are not stretched and the machine is level.
1helpful
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
2answers
Leaks occur in spin/empty cycle
I had the same problem, you need to turn the washing machine on it's side and look for a pin hole leak in the seam of the plastic holding drum on the bottom. I used a silicone sealant, "GOOP" , let it dry for 1 day and problem solved. It has not leaked in two years. good luck!
13helpful
5answers
Top Avanti Washing Machines Experts
Kolbrun...
john h
Jorgie  the...
Jorgie the...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
