Question about NorStar Lands Phones
How do i set the dial tone on norstar m7310 telephone to default line 3?
Posted by Eleanor Barbey on
5 Related Answers
Chintu-KPV
Chintu-KPV
  • 202 Answers
SOURCE: Norstar m7310 phone
Go to 'Setup / Feature' -> look for the menu item with option as Tone OR pulse...this is where u have to change :)
Posted on Feb 09, 2008
Anonymous
  • 326 Answers
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue Norstar M7310 corded telephone
  1. Press feature
  2. Type **266344
  3. On password type 266344 (wont show the numbers as you putting them in)
  4. Terminal + extns will appear, press line 6
  5. Find ext number, type number and the name will show up
  6. Press line 6, line access will appear
  7. Press line 7 twice and change will appear
  8. Enter the name then press line 1
End session and save
worked for me, hope it helps
Posted on May 05, 2008
ynotphone
ynotphone
  • 192 Answers
SOURCE: M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Posted on Mar 20, 2009
Anonymous
  • 60 Answers
SOURCE: Norstar M7310- buttons don't produce tone anymore
Have you tried un plugging then plugging them back in to reset them, if not you may have to power cycle the main system.
Posted on Jul 28, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How do we remove an extension from a hunt group in
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool2.gif on.
Press the next key 6 times (bottom right arrow) .
The display should say System Prgrming.
Press the show key (top right arrow)
The display should say Hunt groups
The display should say Show Group:
Enter in the group number of the member that you wish to delete.
The display should say Member DNs:
The display should show members for that group.
Scroll to the member you wish to delete.
Press the Remove soft key.
Press the heading key(top Left arrow) till the display says Show Group: again.
Enter in the group number you wish to to change the deleted member to
The display should list the current members of that list
press the Add soft key.
enter in the DN of the member you wish to add
Select Appr & Ring setting for the hunt group member
Press the release key when finished
Posted on Oct 01, 2009
How do I set dial tone on line 3?
If you mean for line 3 to be selected when you pick up the handset, you need to program that as the "prime line" for that set.
Sep 30, 2015 | NorStar M7310 Corded Phone
My Meridian M7310 phone system is unable to receive or give out going calls on Line 3 only. In addition there is no dial tone on that line only. The other 4 lines are working great. I have already gone to...
Either the line from the telephone company is out or the line port in the line card is defective. The easiest way to determine if its one or the other is to report the line trouble to the telephone company. they'll check the line up to where it comes into the building, and if theres a problem on thier side they'll get it back in service. If the report the line is good to the building, then you'll need to call your telephone system service technician.
Jul 28, 2010 | NorStar Meridian M7310 Phone
How can I get the dial tone turned back on without lifting receiver? I want to be able to lift the phone and answer without pushing Line 1
To answer a ringing line by just lifting the handset that phone has to be programmed to ring on that line. This is done in the programming mode under 'terminals&sets/show set__/Line Access/Line assignment/Show line:__/...then your choices are: Appear and ring,Appear only, or Unassigned. Choose appear and ring on each line you want to answer from that telephone. Hope this helps.
Bill C. www.dyna-tech.com We also do remote programming and tech support on Norstar CICS and MICS.
Apr 09, 2010 | NorStar M7310 Corded Phone
We have the Norstar Meridian (M7310)telephone system in our non-profit organization. Recently there was a change in our service providers and since that time we have had nothing but problems with our...
Could be two things, there could be a general delivery mailbox attached to the system which is mail box 100, or the new service provider has a off premisis voicemail attached to the lines. if there is VM on the lines you should get a stuttered dial tone on the line indicating that you have a voice mail.
Oct 13, 2009 | NorStar M7310 Corded Phone
How do i get to system programming on my norstar m7310 to get to auto relocate
Enter Administration Mode
  • Using you telephone set push feature * * 266344
  • Display will read Password
  • Using you telephone set enter password: 2 6 6 3 4 4
  • Display will read Configuration
  • Press Show
  • Display will read Trk/Line Data
  • Press Show
  • Display will read Sys speed dial
  • Press Next several times until the display reads Set relocation: Y or N
  • Press Change until the phone displays Y for ON or N for OFF
Jul 02, 2009 | NorStar M7310 Corded Phone
Its the problem from the system.
Go to the programming of Norstar by Feature **266344 and the password is 266344.
Go to line datd or line and make dialling made as Tone.
It will fix ur problem.
Apr 21, 2009 | NorStar M7310 Corded Phone
How do I change the default line on our phones
restore the factory settings of your mobile byentering the security code of mobile.
Feb 04, 2009 | NorStar M7310 Corded Phone
Vintage phones cannot dial out
Any standard phone should work, even phones made in 1800's should still work on a standard phone line.
I'm not sure what phone you have. The one listed in the question "M7310" is a business system phone and will ONLY work on the Nortel business phone system.
If you have standard home phones, my only suggestion (using the information supplied) is to check if the Tone/Pulse switch is set to tone... even though both should work.
Do you have phone service through a cable line?
May 28, 2008 | NorStar M7310 Phone
Norstar m7310 phone
Rushy: I assume you have a KSU which controls the entire system. The KSU is cabled to each line number provided by your local phone company. Once you have this line established it now makes contact with your phone set via dedicated cabling to each telephone set.. With all this hardware in place you can now program the line keys on each set for either one touch dialing or line access for your dial tone. Program guides can be aquired through GOOGLE by entering " Norstar m7310 program guide".Thank You. Jerry
Feb 08, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
60 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
