Question about SanDisk Sansa e200 MP3 Player
SanDisk e260 "Load Main Image Failed.Switch To Recovery Mode"
Posted by nelsonz6 on
Timothy D
  • 626 Answers
Try This;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Nov 16, 2007
My e260 is saying "load main image failed switch to recovery mode" what that means
Load main image failed, this is a firmware error, (this does not have software like a computer)
Recovery mode, the player tried to recover from the error.
The player has firmware updates that where put out by the MFG because of problems.
You have to read the manual, carefully and follow it to the T.
because you need to update the firmware on the player.
This is there website.
http://kb.sandisk.com/app/home
Feb 08, 2010 | SanDisk Sansa e200 MP3 Player
Load main image failed SunDisk Sansa e280r rhapsody Refurb
load main image failed Switch to recovery mode e260
Aug 05, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Download the Sansa Recovery Tool from sandisk's website
Jul 06, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Donwload the Sansa Recovery Tool form Sandisk's website
Jun 26, 2008 | SanDisk Sansa e260 MP3 Player
Sensa e260
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Best of Luck.
Sep 05, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
116 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
