Samsung UA-46D6000 46" Series 6 Multisystem 3D LED TV FOR 110-220 VOLTS Logo
C
CU Jayakumar Posted on Sep 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Double image fault ..replaced T-con board but still same fault what may be the fault may be in power supply? any one can help to rectify the fault
Double image fault
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Oct 04, 2015
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986646
Points
237762
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Mar 31, 2012
SOURCE: The image is blurry (ghosting) and dark.
the tab bonds on the lcd panel where they attach to the Drive circuits above the TCON samsung is famous for bad flex tab bonds. Does the screen appear llike its in slow motion and double immages in that half of the screen as well as appear to have dark bands aross the screen? If so its probably the flex tab bonds.
gopakumarg43
  • 76851 Answers
  • Posted on Dec 04, 2012
SOURCE: won't switch on
You reports that you've changed the T'Con board. Where is the T'Con board to a Plasma TV? There is no such board to any plasmas. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Back2life Electronics
  • 933 Answers
SOURCE: there is double imaging on my samsung tv, i replaced the tcon board and it still has the double image.
does it go away when the set warms up? or if you tap the set? Sounds like a possible defective LCD panel tab. Samsungs and Sony's are known for this.
Harrie
  • 6746 Answers
  • Posted on Jan 21, 2015
SOURCE: how can I fix a double image my Samsung tv is putting out? I replaced the t-con board and nothing. what step should I take next?
The best step you can take now is to hire a tech. He or she wont replace things that are not defect. They will find the defective part and only replace that. Most of the time I spent more time to diagnose the error, than it takes to replace the defective part. But i diagnose is not made by replacing stuff till it works. In the end you can have defective components for 2 or 3 complete apparatus and it would still no work. Sometimes you can be lucky, but most of the time you are not. You don't have to take my word for that and look how lucky you are.
the_housedoc
Raj Parmar
  • 9 Answers
  • Posted on Feb 04, 2015
SOURCE: Samsung lcd model la32s81b sound is good .Fault is blank screen with no display or if u want white screen.
It could be either or. More then likely it is your mother board, which is the brains of your t.v.
Testimonial: "Thanks for the help .the faultis not on the mainboard ,it is the fuse on the t-con board was blowm. So l replace it. The tv is ok & already delivered.thanks ."
1helpful
Replaced the power supply/backlight inverter board and T-con boards on my Samsung 37" TV Seems worse than before
hi this is usually is a tcon board fault, but it can also be a bad panel, if it's flashing could a mainboard fault thanks
shaun
1helpful
Samsung LED TV (UN39FH5000FXZA) has audio, but does not have backlight. I replaced the power supply/ LED board with no success, could this be caused by the main board or the t-con board?
Hi Matt,
The fault lies with the backlight LEDs. It is common with these sets. If you open the panel and replace the failed LEDs, or replace the panei.
Good luck.
Westinghouse VR-4090 Issue double image on screen. I disconnect the right ribbon from T-Con to LCD go's away. Bad T-Con board?
Possibility. Replace the same and check. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
Philips 32inch LCD tv.. when powered on runs fine for 5 mins and then it flicks and double image starts.. What will be the problem???
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Technika TV bought April. 2013. Flickering picture and double vision appearance(as if 2 non aligned images). Same on DVD or Sky channels. Help.
Trembling and vertical overlay image : how to fix it ?
Main power supply regulator board fault. DC voltage output from it is abnormal. Contact any service technician.
It will be best to replace the power supply regulator board as card basis.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
