You can give this a shot....
Turn off your 360 UnitRemove all memory devices
restart 360 Unit
go to system blade > Console Settings > System Info
press left trigger, right trigger, x, y, left bumper, right bumper, up, left bumper, left bumper, x.
This should bring up a menu
Reset System Settings
Resetting your system settingswill return all console settings tofactory defaults.
Do you want toreset to factory defaults?
Yes, reset settings
your screen should go blank for about 2 seconds then the language blade should appear that lists several different languages,select your preferred language then a blade that says "Xbox 360 Storage Device" should appear
With the options of
1) Done
2) Continue without one
select to Continue without a profile
Then an Initial Setup Complete screen should appear with the options of
Family Settings
High Definition Settings
Xbox Dashboard
select Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on
Parental Control lock should be disabled
SOURCE: removing old parental lock out codes on used ps2
here is the answer to your prayers http://www.techlore.com/article/10505/
SOURCE: Xbox 360 reset Code
Since that didn't work. Try to go and run "Initial Setup" again on the 360. That should solve the issue. If somehow it doesn't just give Microsoft a call at 1-800-4MY-XBOX and they CAN take care of that for you.
SOURCE: master reset for xbox 360
navagate to console settings and go to the bottom item on that list. select the item to make changes and enter
LT RT X Y LB RB Y up left up
confirm the reset and your good to go
SOURCE: Forgot Xbox 360 parental controlls password
they can either use the password reset answer or contact xbox live via the phone.http://support.xbox.com/support/en/us/nxe/contactus.aspx
good luck
Here is the procedure to reset the parental lock code:
