SOURCE: only cold water in my tub hot only trickles
Usualy when this happens you need to change out the cartrage that controls the water. try to find your faucet at the link below. If you find it click on it scrol down and you can view the manual. It will terr you how to change it out.
http://www.deltafaucet.com/bath/index.html#tubshower_
Good Luck
SOURCE: When the Moen shower is on half the water comes
You need to replace the diverter, if on the end of the tub spout replace the whole spout.
Testimonial: "Thanks for the advice. Very kind and helpful."
SOURCE: Installed a new oak brook collection tub and
Most all shower valve's these days have anti-scald protection. There are 2 ways that this protection is accomplished; temperature control device or a pressure balance device.
If your's has a pressure balance device, both cold and hot water lines that supply your shower valve must be fully opened. If you only turned on one, water will not flow from the shower valve.
If both hot and cold supplies are fully opened and you soldered copper pipe to the shower valve, it is possible that excess soldered is was sucked into the valve and could be obstructing the valve's outlet.
SOURCE: Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
SOURCE: adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
