Question about Timex Ironman Watches
My Timex will jump back 2 hours. At other times it will jump back 2 hours. Can this be fixed?
Posted by Michael Golden on
ray gallant
    Top Expert:
  • Timex Master
  • 69,189 Answers
Sorry we are not watchmakers here perhaps TIMEx could tell you
Posted on Sep 30, 2015
I have a timex iron man watch. It jumps ahead 2 hours on occasion. Another time it jumped back 2 hours. what can I do?
There appear to be many versions of this watch. The first think I would check is the instruction book. It may be dual time zone? Amazon ca timex ironman Timex Watches
Sep 30, 2015 | Timex Ironman Watches
How to set a Timex 1440 ports watch WR50M
Buttons are numbered as followed:
Start/Stop is button 1
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
a) Press 4 to select "TIME" mode
b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
c) Press 1 to reset digits to 00.
d) Press 4. Minute digits blink
e) Press 1 to set minutes.
f) Press 4. Hour digits blink.
g) Press 1 to set hours.
h) Follow same patter to set day of month, month, etc...
i) Press 2 at any time to retain set values and exit procedureSource(s):Timex instruction manual
Oct 08, 2012 | Timex 1440 Digital Sports Watch - Green
How do u get hourly beep to turn off on digital watch
To set time, date, and options:
1) With time and date showing, press and hold SET.
2) Current time zone (1, 2, or 3) flashes. Press + or to select time zone to set, if desired.
3) Press NEXT. Hour flashes. Press + or to change hour (including AM/PM); hold button to scan values
4) Press NEXT. Minutes flash. Press + or to change minutes
5) Press NEXT. Seconds flash. Press + or to set seconds to zero.
6) Press NEXT. Month flashes. Press + or to change month.
7) Press NEXT. Day flashes. Press + or to change day.
8) Press NEXT. Year flashes. Press + or to change year.
9) Press NEXT to set options. Press + or to change value and then press NEXT to go to next option. Press DONE at any
step to exit and save settings. Available options are 12- or 24-hour time format, MM-DD or DD.MM date format, hourly
chime N, beep for button presses, customizable mode set (Select “HIDE” for unwanted modes – they are removed
from mode sequence).
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Aug 31, 2010 | Timex Watches
How to set date in Timex T2M710?
mcdevito75 here, Your Timex stem (winder) has 2 positions, slip a fingernail just under the crown (winder) and lift the crown to it"s first position this will allow you to change the DATE (number) with out haveing to go thru the 24 hour cycle some many times. It may take a little practice but the stem has those 2 positions. Set the date to the date before the date you want then push the stem back in, Now pull the stem out and go around the 24 hours to set the date and time of day you want.
Jul 05, 2010 | Watches
The minute will set only on half hour increments
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please .
Apr 07, 2010 | Timex 1440 Prizefighter 53032 Sports...
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Oct 09, 2009 | Timex 1440 Nylon watch
How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Mar 11, 2008 | Timex 1440 Nylon watch
Timex Mid Size Sports 1440 WR50M
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps:
1. Press Lap/Reset and hold. You should see the time the alarm was set for.
2. While holding Lap/Reset, press Mode.
3. Let go of all buttons.
4. There you go!
Hope that was a help
Hour hand incorrectly positioned
hi Jim the hour hand is easy to be fixed but by pro qualified , it is a matter of little drift to back words so don't worry for the 100 Mwater resist if the person opened the back cover of the watch then he have to replace the rubber belt at the border of the cover case and then evry thing for the water resist will be good regards , and plz don't forget to rate , remember i am here for help thx
May 08, 2007 | Timex Expedition® Outdoor Casual...
Watches Logo
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Timex Watch Expert? Answer questions, earn points and help others
