Canon Pixma MX410 All-In-One Printer Logo
Jean Lockwood Posted on Sep 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Type is smudged. Changed cartridge and cleaned nozzle,etc. but didn't help
steven beasley
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 105 Answers
  • Posted on Sep 30, 2015
steven beasley
Expert
Level 2:
Night Owl:
Answers
105
Questions
Helped
32211
Points
240
The alignment is off.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
2answers
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
1helpful
Cleaning inkjet nozzles
Here's what I found here:
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Cleaning the print cartridge nozzles
To improve print quality, you may need to clean the print cartridge nozzles.
Clean the nozzles when:
• Characters are not printing completely.
• White dashes appear in graphics or printed text.
• Print is smudged or too dark.
• Colors on print jobs are faded or they differ from the colors on the
screen.
• Vertical, straight lines are not smooth.
43
You can use the operator panel or the Lexmark X5100 Series Solution
Center to clean the nozzles.
Using the operator panel
1 Load paper in the All-In-One. For help, see page 16.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 To further improve print quality, try wiping the print cartridge nozzles
and contacts (see page 44), and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
1 Load plain paper in the All-In-One. For help, see page 16.
2 Click Start Programs Lexmark X5100 Series Lexmark X5100
Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
clogged nozzles.
6 Print your document again to verify your print quality has improved.
44
7 To further improve print quality, try wiping the print cartridge nozzles
8 If print quality has not improved, try cleaning the print cartridge
Wiping the print cartridge nozzles and contacts
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges. For help, see page 38.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Hold a clean, damp section of cloth against the contacts for about
three seconds. Gently blot and wipe dry in one direction.
Nozzles
Contacts
45
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print cartridge
8 If print quality is still unsatisfactory, replace your print cartridges. For
help, see page 38.
2answers
How do I get rid of black smudges and smears when printing. Have cleaned ink nozzles, cartridges and the problem seems to worsen
Check under the cartridge holder. Sometimes fluff causes a ink buildup ink catridge and the cartridge holder. Clean under the cartridges and the cartridge holder
Good luck
Faint printing after cartridge change & head cleaning
How about nozzle check output? Is it perfect? No missing lines? Do head cleaning, wait for 30 minutes. Check nozzle again. If there are no difference betwen two output, you may need cleaning head manually.
1helpful
5helpful
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Print is Smudged
you may try
1) clean the cartridge nozzles with dry soft paper
2) clean the cartridge carriage down side surface there might be bled ink.
3) check the cartridge up side there is the lable cover the ink refill hole is ok, no any lable stick there you need put stick lable there.
1helpful
Print problem with Cyan cartridge
i had to run 10 cleaning to get a printer to print magenta. finally it cleaned it self..it gets expensive..leaving your printer on keeps the in nozzles clean..when its off for long periods it dries in the nozzles.
Printer will not print
Ren, Does the printer show the cartridges have been changed? If the printer doesn't recognize the new cartridges, turn off the computer and unhook the printer, unplug the printer from the computer and electric. Turn on the computer so it boots without the printer hooked up,(2x) then shut down again. Rehook the printer and plug it in then reboot the system. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=41661&prodoid=46048263&infoType=Downloads&platform=All You can also find updated drivers from epson from here. Good Luck, Tim
old marine
old marine
ZJ Limited
ZJ Limited
