Invacare Pronto M91 with SureStep Logo
theodore buchanan Posted on Sep 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spj-80, model 1122190. Why doesn't it move?
2red flashing lights 5 times when i move toggle switch battry fully charged char will not move
Scooter Doctor
Level 3:
Master:
  • Invacare Master 401 Answers
  • Posted on Apr 12, 2016
Scooter Doctor
Invacare Master
Level 3:
Master:
Answers
401
Questions
0
Helped
122720
Points
1542
You may have a current rollback problem you will need to charge the Chair for 14hrs. with the Joystick on! This will reset the circuit. Charge with the joystick on! It is okay it won't hurt a thing, in fact from now on always charge with the joystick on.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
1helpful
3answers
The self-diagnostic light is flashing 5 times for a brake fault.
CTM info on flashing 5 times is CHECK FREEWHEEL LEVER IS IN DRIVE,,check wiring .connections good luck
Battries fully charged, turn key on and only beeps 5 times. Thats all.
hi Hal, that is a issue around based the brake or connectors to the brake or the micro-switch that is moved when you move the drive , freewheel lever.. ... firstly make sure the scooter is in drive mode and not free-wheel mode ., where the axle comes apart you will see a number of connectors , make sure they are a good fit ...
Update me please...
Regards
Rob
Pronto m91
You are getting a motor error code. Check motor wiring and connection to the main control box. Motor may have gotten unplugged when changing the batteries.
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
I have a 12v cordless drill and after todays work i put battries on charge and the red light was flashing when normally the red light stays on constant has the charger developed a fault or are all three...
Let batteries cool down before charging, too much heat from the battery tricks the charger into thinking the battery is fully charged or is broken
Jul 12, 2011 • Garden
My nissan 95 truck won't start. the battery is ok. once it wouldn't start and i put it in neutral then back to park and it started right up. where is the neutral safety switch located? I heard...
I think your reverse to park trick was a fluke,, I assume it turns over but since it is a 1995 you dont have a OBD 2 in the vehicle.
How to pull ECU error codes for 87-95 Pathfinders and Hardbody pickups:
The ECU is under your passenger's side seat. You can gain access to it by simply sliding the seat all the way forward and removing the plastic cover from the ECU. You can also remove the seat if you want, it makes access a little easier.
The VG30i ECU's have a tiny toggle switch on the side of the ECU with a small snap-in switch cover that must be utilized to select the diagnostic mode of the ECU. The 4-cylinder ECU and the VG30E ECU has a slotted switch that turns 1/4 or 1/2 turn clockwise and counterclockwise to do the same task. Some early 4-cyl HB ECU's have the switch as well. In any case it will have one or the other.
For 4-cylinder:
1. Turn the ignition switch on, but do not start the engine. All of the lights in the dash should be on.
2. Turn the 'diagnostic mode selector' screw on the ECU fully clockwise. The check engine light will go out. Wait 5 seconds, then turn the screw fully counter clockwise.
3. The check engine light will then begin to flash the trouble code. (number of long flashes is the 1st digit, number of short flashes is the 2nd digit)
4. To clear all stored codes and turn the check engine light off, turn the screw fully clockwise while it is in diagnostic mode. Wait 5 seconds, then turn the screw fully counter clockwise.
5. To keep the codes stored, simply turn the key off as the check engine
light is flashing and the ECU will keep all stored codes and the check engine light will remain on.
For V6:
2. For VG30i: There is a little plastic tab you pull off of the side of the ECU(facing the door). A small toggle switch is behind it with 2 positions, "ON" and "DIAGNOSTICS". Using a small screwdriver or tool, move it to the diagnostics position. The red and green LED's on top of the ECU will blink simultaneously. One time, pause, then 2 times, three times, pause...so on for each mode, 1 through 5. Mode 3 is the most commonly used mode and will yield the ECU trouble codes you need to figure out what's going on with your engine.
For VG30E with slotted switch: Turn the 'diagnostic mode selector' screw on the ECU fully clockwise. The check engine light will go out. Wait 5 seconds, then turn the screw fully counter clockwise.
3. After it blinks both LED's 3 times move the toggle switch back to the on position. After about five seconds it will start to output out the diagnostic codes as with the 4-cylinder ECU. Note each code as it is displayed, the red LED flashing once for 10's, and the green LED flashing once for 1's. Meaning: One red flash and two green flashes means code 12.
4. To clear the ECU of any trouble codes, move the switch to the "DIAGNOSTICS" position then back to the "ON" position and turn off the key.
1986.5-1995 Nissan ECU Flash Codes(all engines)
11 Crank Angle Sensor/Camshaft Position Sensor.
12 Air Flow Meter/Mass Air Flow Sensor.
13 Engine Coolant Temperature Sensor.
14 Vehicle Speed Sensor.
21 Ignition Signal.
22 Fuel Pump.
23 Idle Switch.
24 Throttle Valve Switch.
25 Idle Speed Control Valve.
28 Cooling Fan Circuit.
31 ECM.
32 EGR Function.
33 Heated Oxygen Sensor.
34 Knock Sensor.
35 Exhaust Gas Temperature Sensor.
36 EGR Control-Back Pressure Transducer.
37 Knock Sensor.
38 Right hand bank Closed Loop (B2).
41 Intake Air Temperature Sensor.
42 Fuel Temperature Sensor.
43 Throttle Position Sensor.
44 ECCS Normal Operation.
45 Injector Leak.
47 Crankshaft Position Sensor.
51 Injector Circuit.
53 Oxygen Sensor.
54 A/T Control.
55 No Malfunction.
63 No. 6 Cylinder Misfire.
64 No. 5 Cylinder Misfire.
65 No. 4 Cylinder Misfire.
66 No. 3 Cylinder Misfire.
67 No. 2 Cylinder Misfire.
68 No. 1 Cylinder Misfire.
71 Random Misfire.
72 TWC Function right hand bank.
73 TWC Function right hand bank.
76 Fuel Injection System Function right hand bank.
77 Rear Heated Oxygen Sensor Circuit.
82 Crankshaft Position Sensor.
84 A/T Diagnosis Communication Line.
85 VTC Solenoid Valve Circuit.
86 Fuel Injection System Function right hand bank.
87 Canister Control Solenoid Valve Circuit.
91 Front Heated Oxygen Sensor Heater Circuit right hand bank.
94 TCC Solenoid Valve.
95 Crankshaft Position Sensor.
98 Engine Coolant Temperature Sensor.
101 Front Heated Oxygen Sensor Heater Circuit right hand bank.
103 Park/Neutral Position Switch Circuit.
105 EGR and EGR Canister Control Solenoid Valve Circuit.
108 Canister Purge Control Valve Circuit
ECU Diagnostic Mode Procedures
Mode I - Exhaust Oxygen Sensor Monitor
Use Mode I to determine if the Oxygen Sensor is functioning properly.
Warm the engine to normal temperature.
Run the engine above 2000 RPM under no load while looking at the ECU.
Make sure the GREEN LED goes on and off more than five times during ten seconds at 2000 RPM.
If the number of flashes are not more than five, replace the oxygen sensor. If the LED does not flash, check the sensor's circuit.
Mode II - Mixture Ratio Control Monitor
Use Mode II to determine if the air/fuel mixture is cycling correctly.
Warm the engine to normal operating temperature.
Turn the dial on the ECU fully clockwise (or if you have a switch, turn it on).
After the LED flashes twice, turn the dial fully counter clockwise (or turn the switch off).
If the RED LED blinks simultaneously with the GREEN LED, the air/fuel mixture is cycling properly.
If the RED LED stays off, the mixture is more than 5% rich.
If the RED LED stays on, the mixture is more than 5% lean.
If the RED LED stays on or off above 2000 RPM, complete the diagnostics before beginning repairs.
Mode III - Stored Fault Code Reporting
Use Mode III to retrieve all stored trouble codes in memory.
Use the above posted procedures.
Mode IV - Switch Operation Monitor
Use Mode IV to determine if the Throttle Position Sensor (TPS), Starter circuit and/or Vehicle Speed Sensor (VSS) are in proper working order.
Turn the dial on the ECU fully clockwise. After the LED flashes 4 times, turn the dial fully counter clockwise.
Make sure the RED LED is turned off.
Make sure the RED LED turns on when depressing the gas pedal. If not, check or replace the Throttle Position Sensor.
Make sure the RED LED turns on when turning the ignition key the START position. If not, check or replace the starter.
Drive the vehicle with the ECU unbolted and within view. Make sure the GREEN LED turns on when speed is 12 MPH or more. If not, check or replace the Vehicle Speed Sensor.
Mode V - Real Time Diagnostic Function
Use Mode V to determine if the Crankshaft Position Sensor (CPS), Mass Air Flow Sensor (MAFS) and/or Ignition signal are working properly.
Start engine.
After the LED flashes 5 times, turn the dial fully counter clockwise.
Make sure LEDs do not flash for 5 minutes when racing or idling the engine.
If it flashes, count the number of flashes, turn engine off, and see the following 3 paragraphs. Perform real-time diagnosis inspection and repair or replace malfunctioning part if present.
if LEDs do not flash for 5 minutes, turn engine off.
If the RED LED flashes 3 times for 1.5 seconds, check the Crankshaft Position Sensor. Check the harness continuity at CPS when the engine is stopped. Inspect the harness for dust and clean if necessary. Check the pin terminal at ECU for bends and remove them as necessary. Reconnect harness and recheck continuity. During real-time diagnosis, tap the harness connector or component and check if trouble code is displayed. If so, replace terminal.
If the GREEN LED flashes twice-3 times for 0.5 seconds, check Mass Air Flow Sensor. Check the harness continuity at MAFS when the engine is stopped. Inspect the harness for dust and clean if necessary. Check the pin terminal at ECU for bends and remove them as necessary. Reconnect harness and recheck continuity. During real-time diagnosis, tap the harness connector or component and check if trouble code is displayed. If so, replace terminal.
If the GREEN LED flashes 4 times for 0.2 seconds 3 times, check the ignition signal. Check the harness continuity when the engine is stopped. Inspect the harness for dust and clean if necessary. Check the pin terminal at ECU for bends and remove them as necessary. Reconnect harness and recheck continuity. During real-time diagnosis, tap the harness connector or component and check if trouble code is displayed. If so, replace terminal.
Hope this helps...
__________________
G600 problem
is the phone charged fully, if so strip the phone and leave it separtred for 15 mins and put it 2 gether a again
My i pod
get a new batty. the battry problay wasnt fully filled up when first charged. When you get the new battry, go to google n search how to repace the battry for your ipod. do this then remember to fully charge the ipod up the first time. other wise, this is the limit that the battry will charge to the furthur times and the limit will slowly decrease. untill its at your stage
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
