Question about LG LS-L1210CL Mini Split Air Conditioner
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Posted on Aug 30, 2007
SOURCE: Remote Problems
you dont leve the remote in the sun do you? could be an issue
Posted on Jan 25, 2008
SOURCE: LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Posted on Jun 24, 2008
SOURCE: LG SPLIT SYSTEM AC.
Fixed fault by not only switching off AC unit at power point, had to pull out plug top & lead from wall for one minute. This must allow electronics to reset.
Posted on Feb 01, 2009
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Posted on Jul 20, 2009
Jul 23, 2018 | Heating & Cooling
Aug 09, 2016 | LG Heating & Cooling
Feb 07, 2016 | LG Heating & Cooling
Oct 11, 2013 | Innovage Jumbo Remote Control
Sep 29, 2013 | LG Heating & Cooling
Aug 17, 2012 | Heating & Cooling
Dec 10, 2010 | Heating & Cooling
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
Feb 15, 2009 | LG LSC121PMA Split System Air Conditioner
May 13, 2008 | LG LSC183VMA Split System Air Conditioner
120 people viewed this question
