Question about Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser -
The crush function works for my ice maker but not the cube function . What can I do to fix it?
Crush ice is fine but when I press the button for cubed ice nothing happens. No beep no light. Any ideas.
Posted by marvin kennedy on
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Maytag MSD2651KES delivers crushed ice but no cubed
There is an metal arm that extends out behind the ice bucket that moves up and down when you press the cubed/crushed ice buttons. You need to take the ice bucket out and check the hardware. It's possible that some ice has managed to form in the unit and are blocking the motion. Remove any ice and check if the arm moves freely when you press the buttons on the refrigerator. Similarly, you should check if there is ice blocking the forward and back motion of the plunger in the freezer that bar sits on. This plunger is right next to the auger motor.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MSD2651KES/3048/0165000/W0703730/00013 has a picture of the ice bucket parts.
Dec 06, 2013 | Freezers
Ice maker will not separate ice cubes
Check if your water filter is up to date, if not check if the ice maker has the option to choose the side of the ice cubes, if so, set it up to medium side.
Apr 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker has stopped making ice
Check the ice maker to see if there are ice cubes in the ice maker. If so, there is a problem with the ice maker heater and / or motor. You may be able to rebuild the ice maker by replacing defective parts, but it might be easier to replace it as a whole unit instead. If there is no ice present, it is likely a problem with the ice maker water lines / solenoid.
There are usually two solenoid valves and tubing systems for these types of fridges. One actuates on demand for water whenever requested, and the other operates automatically to make ice cubes until the ice cube reservoir is full.
Carefully push/pull the fridge away from the wall.
Unplug the fridge from the outlet.
Shut off the water supply to the fridge.
Remove access cover (usually the on the bottom) from the back of the fridge. Follow the tube that comes from the top of the fridge (for the ice maker) down to the bottom of the fridge.
Inspect visually for sources of the leak on tubing and related parts. Carefully check by hand for leaks in areas not readily visible - including the back sides of all the tubing, too. There may be sharp edges that can cut if not paying attention. If a leak is found where the tubing connects to other parts, you may be able to simply remove the tube and cut it back an inch or so if there is enough slack.
It may require that some special fittings and parts be obtained to reconnect and some compression type parts are designed for single use. If this is the case, gather the parts and bring them to a local hardware store for assistance obtaining replacements.
If a solenoid valve is found to be the culprit, due to a crack, etc. a trip to an appliance parts store will be required - unless able to purchase online. Part prices can vary widely , depending on the source.
Once replacement parts have been secured, reconnect after disconnecting power & water supply lines. When satisfied with the installation, reconnect power and water lines and test.
Carefully slide the fridge back into position - taking care to not crush the power or water lines.
Dec 31, 2009 | Freezers
Floating bits in Whirlpool fridge-freezer crushed ice water
Ice cubes freeze from the outside, so the center of the cube is the last to freeze. Ice is pure water, only H 2 O, so as the ice cube freezes, all of the dissolved minerals are pushed to the center. Near the end of the freezing, there isn't much water left in the center of the cube, so these minerals become very concentrated, and they form the "white stuff" – the technical name is precipitate. The hardness minerals that cause the "white stuff" are not toxic.
Mar 20, 2009 | Freezers
Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser - Logo
110 people viewed this question
Top Samsung Freezers Experts
Tad
Level 1 Expert
Harrie
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
